Got my Aeroforce gauges and boost gauge installed in the Grand Prix. Now all I have to do is figure out why that battery keeps needing a boost. It checks out fine as far as voltage and then it will just drop from 13.5 to 9.5... :dunno: Gotta get the charging system checked out...Might be the issue... Either that or something in the battery has gone bad...even though it's only about 2 years old.
Where are the pics?
We all cruised tonight
My daughter as of a few days ago can now drive the car. Not good having two kids fight over it
Ryan
Buy her one. Its fair, and more importantly will save you grief.
He is getting to big for it time for him to pass it down
Ryan
Ryan
Thats what he will be saying about your Camaro in a few years :lol:
Where are the pics?
Once I get the charging issue fixed and wire the gauges so they shut off with the ignition.
Gave her a bath, clayed, kaio, and a coat of nattys blue. She needed some tlc. The sierra needs one but ran out of time. 2015-09-24 13.38.08.jpg
Sent from my Note 4
Never tried to clay a dog before :D
Edited by SnakeEyes
Never tries to clay a dog before :D
Haha. Yea, that's my little guy. He literally photobombed every pic I took!!
Sent from my Note 4
Our Pekingese was like that until we had kids. We have a bunch of old pictures with her head just peaking into the shot.
New exhaust and tires today, not a cheap day…
255/60r15's on the back and 235/60r15's up front, a lot more rubber then the small 215/65r15's that were on there when I got it…
I entered into the Good Guys show this weekend.... It is going to be one hell of a rat race.
Not sure I miss mine(just the power). That last experience truly did ruin classics for me.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
