Nice!
Stared sadly at mine. Got in a fender bender Saturday, now she isn't driveable. I can fix it, just maddening that this happened so close to graduation.
Sigh.
Before
After
Outside pic tomorrow
Looking great!
Amazing how so many don't take the time to keep their vehicles nice.
Nice what did you get it for?
Ryan
$4350, over book but I think with all the new/upgrade it was a decent deal.
The ad text since it was taken down
Re: 2002 Camaro Z28 6 speed silver
I had rear end rebuilt by Lesters gear here in Tulsa Has a new clutch kit and new flywheel, slave cylinder, New plugs, alternator, power steering pump, Rear end has a alburn pro series carrier, summitt racing 373 ring and pinion, Mosier axles 28 spline, front and rear slp shocks and struts, every piece of the strut assy was replaced including kyb mounts, Strano performance lowering springs, bmr front tubular upper control arms, bmr strut brace, umi rear control arms, hotchkis rear adjustable pan hard bar, front slotted and drilled rotors, all within the last 15,000 miles or year and a half, Has brand new !6 in bfg comp 2 tires, not even a hundred miles on them, Rear main seal is leaking, Drivers door window sticks going up sometimes, needs regulator or window run, also has front and rear stabalizer end link replaced at same time, also racetronix fuel pump installed. all at same time about a year and a half ago, Runs great,
Edited by SnakeEyes
Nice - all the difficult and expensive stuff seems to be done already, aside from the rear main.
Our '86 Grand Marquis has been leaking there for the past 13 years of ownership. We just buy oil by the 5 gallon pail. :)
Going to Jack it way up and try to clean the undercarriage. Also troubleshoot a singalbthat won't light up(hope its a bulb, might be a socket)
thatll clean up easy lol
Ditch the steering wheel cover too
Wow, got a little hot there, aye? Chernobyl socket ... :lol:
The guy put it on because that GM high quality soft rubber rim started to disintegrate. Think I'll just get one of those wheelskins. Had one on my BMW and they look good.
I replaced it, it will light up, but it still won't blink. Google results on Camaro sites say next step is a new relay, another common problem.
Edited by SnakeEyes
Flasher fixed it. I bought the last socket so have to wait until they restock or run by other stores until I find another. They all work, for now, but I want a spare. The other front socket wasn't far behind. I think it has been replaced before also.
What's wierd is Amazon says they have it but the pic is way off. But that seems to be common with them and auto parts so might try another if I can't find one locally(cheaper at local stores than amazon).
Going to go for a ride tonight in the 700 RWHP monster Camaro. :thumbs:
Got an after pic, did a NanoSkin(love it!) and Colinite 845
Going in Monday to the shop for a rear seal(double checking that is the problem tonight)
Edited by SnakeEyes
Guess this confirms the rear main? (I AM asking)
Okay guys I cleaned it all up underneath(not super clean but removed all the freshish oil, the super old stuff will need a chisel) and it looked like this:
Then....
A few minutes later:
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
