1 hour ago, qwank said:
Thanks, man.
No motor upgrades yet besides an intake tube and muffler.  I'm going to do a Whipplecharger and maybe long tube headers and call it a day.
Id skip the headers and just remove the 3rd cat.  Theres a dude in town with arh headers with cats, biggest magnaflow muffler and a resonator and its obnoxiously loud still
Thanks, man.
Thats awesome.I just installed a 2.9 whipple and Bryan Tooley stage one blower cam. I am anxious to drive it but I haven't been able to get it up to the dyno to get it tuned yet. It's a 2014 but I put a 16 led front end on it. I have it in the builds section.
That's what I was afraid of.  Maybe I'll just throw some shorty headers on there like I did with my old. truck.  I really like the way my exhaust sounds right now, so I'm even hesitant to gut the 3rd cat.
Id you like the sound. Leave the exhaust side alone. Keep it simple.  Amd bythe way i need those brackets. I want to do the vette brakes fromt and rear
4 hours ago, Lgetz said:
Beautiful truck Danny.  Are those 33 inch Toyo MTs?  Think your truck is fantastic as it is.
Thanks, and yeah theyre 33s toyo mt. Maybe next set ill try to fit a 35
20181020_103555.thumb.jpg.f1fe7453fef0014eb0150dc83e73146d.jpg3.5 rc "lift kit" with their ucas and diff drop. Its a leveling kit and well yes i did do it even after all the bad stuff i read on it. I left the rear stock, and also bilstein 5100 all around. Questions welcomed
I love the look of the single cab trucks. That is a nice setup.
Nice ... how trucks were built before they became four door sedans... like my wife’s 2017 four door Silverado ... which is great for grocery shopping .
Edited by Jp sierra
Opps
On 10/16/2018 at 11:43 AM, vinemann12 said:
My little 2016 RCSB, bone stock from Dealer and after a few mods and tires..
Cheers---K
Nice shell, how does it drive on hwy , I’d figure it the additional weight would make it more stable. Looks amazing brother !
Hey Jp sierra...
I do like your lift and Sierra color...
The Leer Topper is about 225lb which appears to add a bit more cornering traction and stability in winds..
Also,, Don't require any sandbags for winter driving in Iowa.
I did notice some wind buffeting noise between back of cab and topper on Interstate drives but its worth it for the extra dry storage..
Just crank up the Tunes....
This weekend, installing my Hellwig adjustable rear sway bar so,, should be more fun in corners...
Cheers---K
8 minutes ago, vinemann12 said:
Hey Jp sierra...
Cheers---K
Thanks for that info, I’m so leaning on a camper shell .. I would like to add a rear sliding window, I haven’t been able to find one with rear defrost with a  manual window
Hey Jp...
Prior truck was 96 Tahoe with great / dry storage area for camping & fishing equipment..
Now its just me and GF so topper was necessary..
Keep searching for rear defrost window,, I would think aftermarket / custom may be available..
Have you thought of adding insulated HVAC-flex-tubing from one of your lower heater vents to push warm air to window??
Could be cheap and easy fix for basic slider..
Cheers---K
On 10/25/2018 at 7:53 AM, vinemann12 said:
Hey Jp...
Cheers---K
Thanks for that advice , I would just like to keep the defrost function that came with the vehicle , just swapping it with a manual rear sliding window with the heat elements .  I’ve found several manual sliding windows but without the defrost elements... and the as for the top , I can see how useful it would be out at the fishing hole and at the beach .. and keeping my gear out of the elements would be great... I’ll look into one... it reminds me of my 1989 K5.
Dude,, Nice K5...
I miss those days of easy to work-on / simple trucks..
Cheers---K
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
