14 tailgate, 13 badging....
Never liked the big GMC emblem on the back. Decided to order a 2013 GMC tailgate emblem to compliment the sierra logo. Happy with the results...
that's not bad!
Very nice. I'd like to slap some sense into whoever decided to make the front and rear logos HUGE.
Absolutely, it was just too overwhelming for me. Not much I can do about the front one for now....
Looks great! How hard was it to remove the OEM badge.
It was a little time consuming. When removing the emblem you have to make sure all edges are accounted for and you peel it straight off. I've seen a lot of people chip their paint when the corners of the emblem dig into the paint. The whole process would have been a lot easier with a 3m wheel, but their adhesive remover did the trick with some elbow grease. Don't rub too hard, that stuff has been known to damage paint if not used correctly.
Looks great, I was going to do the same thing, have the smaller emblem and all, just never got around to installing it. Thanks for sharing pics, I think I'll make time to do this now!
Looks good. But I like the throwback of the big GMC emblem. I saw a late 80's early 90's sierra the other day and noticed it had a big center mounted GMC emblem. Thought it was cool that an old truck added the new badges, turns out no, thats how they used to come from the factory.
Nice touch, it's subtle, but enough that the truck fans will know the difference…
  • 4 weeks later...
Yep, the rear logo is stupid big. Pulled mine several months ago and left it off.
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
