I have a 2014 LTZ 1500,, About 21,000 miles on it.. The buttons on the key fob are pretty much trashed,, Key is either in my pocket or the truck,, My dealer said they would not even submit it to GM for warranty, because they said they would be told it was abused,, If pushing the buttons to lock and unlock are abuse, I must have a different idea of what abuse is.. Has anyone else had their fob wear like this. I was told by the dealer it would be over $200 for the fob and programing.. way more than I want to spend on a remote. post-48826-0-17008600-1408292846_thumb.jpg
I have a 2014 LTZ 1500,, About 21,000 miles on it.. The buttons on the key fob are pretty much trashed,, Key is either in my pocket or the truck,, My dealer said they would not even submit it to GM for warranty, because they said they would be told it was abused,, If pushing the buttons to lock and unlock are abuse, I must have a different idea of what abuse is.. Has anyone else had their fob wear like this. I was told by the dealer it would be over $200 for the fob and programing.. way more than I want to spend on a remote. attachicon.gifDSCF1154fob.jpg
Is it just a cosmetic issue or are you having problems with the buttons also.
Just give this key fob to your significant other. Lol
the buttons still work,, but not sure how much longer,, I still have the other original that is brand new,, but thinking they shouldn't wear out so soon. Wife doesn't need a key,, she has her own car.
What did you do to it?!
Do you often lift heavy things? I'm guessing that your fob is being crushed while in your pocket. I had a similar problem with a blackberry years ago. you can get protective silicon cases for FOBs. I would suggest buying one or a carabiner-style clip to attach your keys to your pants.
I lift very few heavy things,, retired,,, so I lift a beer now and then and maybe a fishing pole. It is mainly just the buttons that are sinking in. Not sure I have seen a case for a fob and hate having something hanging on my belt
First one I have seen with this kind of wear and tear. I doubt you will have much luck with GM, so I would probably just buy a replacement remote on ebay for about 40-50 bucks. Swap the electronics out so you won't have to bother paying the dealer to program it to the truck for you.
Are you an alien, sweating acid? Just kidding.
I've never seen something like that.
Are you handling batteries or such and grabbed the fob with your work gloves on?
If I was GM I would questioning a replacement by warranty too.
so long
j-ten-ner
Never seen a remote that bad. My 9 yr old remote just had the symbols faded on my old truck
Ryan
Do you run through burning houses in the evenings as a hobby or something??? Wow
Wow I saw a remote from a truck that burned and it didn't look that bad.
If this is a serious post, do as suggested and buy an ebay fob and swap the
insides.
Edited by waumo1
nope,, no batteries, no gloves, no burning houses, not an alien, I try not to work up a sweat, this is the first remote I have had that did this,, about my 4th truck with a remote. No idea what caused it.. guess I am stuck buying another one. thanks everyone
Edited by daveor
Something had to have gotten on it to soften the rubber, could be as simple as a rag soaked with laquer thinner touched it and caused it to break down. Who knows, but sorry for the loss.
I never saw something like that. It looks like it had better days. I would just replace it.
If it's anything like the old ones you can buy the plastic shell and just swap the "chip" into it. I would still try and get a dealer to replace it, shouldn't wear out that soon.
Edited by kstruckcountry
i dont know if your remote is made much different than the SLE other than yours has chrome on it and mine is all black, but the quality of the remotes seems very crappy in comparison to other remotes GM has used over the years.
no clue about it wearing out to the extent that yours did but it just feels very light weight, thin plastic and the buttons suck to push(again in comparison to other GM remotes).
i like the remote they use on the equanox/terrain with the pop out key, but i checked it will contact the shifter on the steering column so we cant use it.
fyi your remote looks like hell, call gm and send them a email with it. be sure to include that this is a personal truck not a work truck.
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
