post-125339-0-89435800-1459808283_thumb.jpgim definately going do the diode trick for the cargo/spot lights but am going to add a switch as well.
top position will be powered by the original power source, center position is isolated from all power and bottom switch will be powered by the accessory plug that i gutted to put the switch in. This will allow me to operate the spots with my cargo switch or turn them off completely or turn them on whenever I want them on.....no more tailgators!
Hey Guys , I recently purchased a 2008 1500 for a steal of a deal , Im interested in doing this mod BUT! the BCM connectors are differant then the ones you guys have, any suggestions?
Just did this but couldn't find the diode listed at radio shack so hacked a coaxial cable and used the core. works great.
Did this to my 15 last night along with my fog lights on with brights.
I hate wiring and this is not that but it gave me the same amount of trouble. Using needle nose pliers I finally got them to work but it's tough getting the diodes in at least for me. Maybe I was using the wrong diodes since they would bend if I pushed it to hard. Anyways didn't get the chance to see what it looks like in the camera but it looked good just sitting there. Hopefully it holds up.
Has anyone done something similar on a GMT900 series. I would like my LED reverse lights to come on with my cargo lights so I can work on my trailer using them just by turning on the cargo lights with the engine off. A diode setup would be good for this and as an added bonus I could flash tailgaters with my reverse lights when needed!
Been meaning to do this cargo mod but it slipped my mind. Was thinking of this though .... is this possible for our trucks? To mod where if we hit the cargo switch during drive that the reverse lights would come on and could flash tailgaters?
I have no wiring background but was thinking that like the one guy on pg1 who did this mod but the opposite way, that that would achieve being able to turn on reverse lights with cargo switch (not sure if im making sense, sorry)
Not sure the cargo lights come on while driving when switch is pressed (to avoid flashing people!!)
I didnt read far enough to thread to find that. I made my post about 6 pages in. After reading further i did say that it was already mentioned that this wasnt possible. Thanks for the replies though.
I see above or maybe a page back that someone had wired/relayed for them to use a switch for their pods which could flash the tailgate drivers. If i get pods then maybe, but i dont see myself adding those
When you say cargo, youre talking about the 3rd break light correct?
Sent from my SGS7
Read all the pages on this thread and I am going to perform this mod but I just wanted to double check. I have a 2016 Sierra that has LEDs on the tow mirrors. Question: is the wiring the same for my truck and will all the cargo lights and the LEDs in the mirrors turn on when I hit the unlock on the FOB?
    RichardRS
    RichardRS
  • Who's Online   0 Members, 0 Anonymous, 805 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
