For those of you that used a wire for this mod - what gauge solid wire did you use?
I'm assuming you used solid wire to be able to push it in?
Or did you just solder tin up some stranded wire?
I used 2 strands of solid cat5 wire twisted
Sent from my SM-G900P using Tapatalk
  • 3 weeks later...
only way will be to use an aftermarket switch. Buddy of mine, whom is also a member on the forum, did it on his 1500.
you'll need to use a momentary (or latching switch, whichever you prefer) and attach it to a power feed, use a diode to prevent back-feeding from the switch to power, then run the switch and again, diode to the cargo light circuit at the BCM, preventing any back-feeding from the BCM to switch. This should ensure that nothing can be back-fed and fried.
Mike 1220, do you think this technic would work on cargo lights as well?
Sent from my SM-G920V using Tapatalk
yep, it will. I haven't tried it myself but see now reason why it wouldn't work. My buddy ultimately attached his to the reverse lights not the cargos, but the same principle should apply. For cargos just wire it the way I described earlier and it should work as you want.
Quick Question, needing to do this mod and I'm thinking of just using a wire to have them go on in reverse and when i hit cargo lights.
The thing is i have factory installed Max Trailer mirrors with the LED lights. will these go on in reverse and when i hit my unlock button?
If you use a wire, yes they will turn on at night when you click the unlock button. I wouldn't do it with a wire tho, because when you are parked and you click the cargo light button, the rest will power on because in a wire current can flow both ways. That's why everyone is using diodes, power only flows one way.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
I figured that would be the case, was hoping they were on a different pin in the harness. I'm not trying to illuminate the entire parking lot overtime i unlock the truck with those things.
i just ordered the diodes off eBay. hopefully will have them by the weekend
I really hate to ask this but is there anyway you could sketch this setup down so it can be understood a little better. My electronics class in college was 30 some years ago and it's all just a little fuzzy to me if you know what I mean.
Kinda of not sure of how to wire the switch.
Sure can. Send me a PM if you don't mind so I can remember to do it later after my test today
- Mike
IG: @BlackPearl_Edition
I may have missed it but did anyone figure out how to get the cargo light to come on in drive and reverse on the early 2015s when you push the button. I saw that you can get them to come on with the reverse lights and that seems easy enough but i don't want that much light every time I back up.
I'm with Derbaby, someone help us figure out how to get the towing mirror lights and the cargo lights to come on while in Drive without shifting to Neutral.
Thank you again to those who've figured out how to get the fog lights to stay on with high beams and the cargo lights with reverse lights, now, just this last missing piece of the puzzle.
So on a 15, can I do this mod and the reverse lights come on with the cargo light button? My truck will already let me use the cargo lights while in reverse but It would be nice to have the reverse lights come on when parked and loading up the back of the truck.
Also, do you guys know if I can change the cargo lights over to led? I changed the reverse lighting to led and like the color and brightness a lot better.
Edited by RhinoGuy
Yes, RhinoGuy. I that's what the 11 pages of conversation were about.
And yes, again, the same bulbs for the reverse lights are in the cargo lights, so change away, as I've done with both.
If you were to put another diode in the opposite direction, then would it allow the reverse light to come on with the cargo lamps when you turn it on via the cab switch since the 2nd resistor would allow the electricity to flow the opposite way of the original?
I am curious becuase I am getting ready to add a VLEDs license plate frame light to add 3500 lumens when in reverse
If the second diode idea works, then I can hook up the light to either the cargo or the reverse, if it wouldn't work, then I would rather hook the light to the cargo lamps so I can use the light at night when I use the cargo lamps.
Mike 1220 I was interested to know if running a second diode the other way worked for turning the reverse lamps on via the cargo lamp switch inside the cab. I currently have the diode running the way El Conquistador showed above. This worked for having the cargo lamps activate when the truck was put into reverse. I have LED pods under the back bumper and wanted to be able to turn them on with the switch inside the cab, not just by putting the truck into reverse.
Thanks in advance
- John
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
