First time to upload pic. Hope this works.
I just bought some relays today at RadioShack, I was planning to do this mod but I am not sure where to put these diodes. Where do I find all those wires? Hood, side door panel?
Thank you,
-Dylan.
Thank you,
-Dylan.
Under driver side dashboard. Tucked up under the dash. Not the big black box on the forward firewall
Does anyone have the link for the fogs on with high or can just tell me what other slot to put the other end of the diode in. I can't quite make it out in the picture that is attached. What color wire do the 2 ends go in?
Did this tonight with just a piece of wire covered in Heat Shrink and push in metal ends. Works like a charm
  • 3 weeks later...
Anyone notice that at times the mirror LEDs simply don't light up at all or are very dim? I had another member ask me about it, no more and more curious as it's becoming more frustrating daily to wonder if this mod will work right?..
does anyone know what slot the reverse and puddle lights are? I've got the new tow mirrors and have that 2 led in the mirror hooked to my puddle lights right now. if i could just jump that connection under the dash that'd be a lot easier then running a straight wire all the way through the door panel and grommet and whatever like i had to do for the amber markers to blink and be running lights
Yes I did it in the tow mirror thread. I'll see if I can dig up the info, I know the cargo light wire is the grey with light green stripe and I think it's in the first connector all the way to the left (closest to the parking brake)
ok that'd be great thanks!
  • 2 months later...
I have tried twice to get this mod to work so that the leds on tow mirrors will turn on. I can not get that puddle light to turn on tho :tear:
  • 4 weeks later...
I just did mod. I was getting a little frustrated cus every time I would try to push the lead inside it would bend. Finally got it done and it works great.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Anyone with Tow mirrors have issues with the LEDs in mirror flickering on one side?
Did not work for me. The Cargo light will come with reverse lights on when I hit the unluck on key fob but when truck is in reverse no reverse lights come on or no cargo lights. I have the correct diode part and installed just as your picture?
Okay so I was inspired by 2 threads here, one being the fog lights on with high beams, which I did and love. The other is a thread about putting a switch in the bed by the tailgate to turn on the cargo lights. That's a great idea but I wanted something simpler, so using the info in the fog light thread, and the link to the wire diagrams, I found the relay switch wires for the cargo lights and the reverse lights then used an extra diode from the fog light trick to connect the two. Now when it's dark and you unlock your doors with the remote, which activates the headlights and reverse lights, the cargo lights come on as well. This does activate the lights by the third brake light as well as the lights in the bed, just as if you pushed the switch on the dash. This is going to activate the cargo lights when you put the truck in reverse also, which will provide more light behind the truck, but it may glare off the rear window as well. I will be testing this tonight to see if I like it or not.
The reverse light relay wire is in the same brown plug as the fog lights. Number 26, its brown with 2 blue stripes.
The cargo light relay wire is also number 26, brown wire white stripe, but it's in the pink plug to the left of the brown plug.
I used the other diode from the 2 pack I bought to do the fog lights ( part # 1N004). The stripe goes toward the cargo lights in the pink plug.
As long as there's not too much glare to see while reversing at night then this should be a handy little trick!!
[/quote Hey so this should work on a 2015 as well right?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
