Question re: Bilstein 5100 Levelling Shocks
I have a 2014 Silverado Double Cab, Z71, and have been doing a lot of reading about levelling kits, and as the topic indicates, the Bilstein 5100 series, ride height adjustable shocks.
I know the 5100's are not yet available for the 2014's, but understand they will be either in late Sept. or Oct.
Anyway, I only want to level the truck, I have no intention of wanting more clearance for larger wheels/tires, I just want to take some of the "Rake" out of it. I have sort of decided that going the "Bilstein 5100" adjustable shock route is somewhat preferrable over that of just a levelling kit.
As I understand it, the 5100 adjustable shock has 4 positions of adjustability; Stock / +150mm (5/8") / +300mm (1 1/4" & +450mm (1 3/4"). I have measured my truck, and in reality show the rear to be sitting about 3" higher, thats measuring from the ground up to the bottom of the fender well. Is this the proper way to measure to obtain a reasonable representation of the trucks "Levellness"? (If there is such a word as Levellness)
My question is more for those that have gone the Bilstein route, I know it will have to be on models older than the 2014, but the end result should be similar:
1. I don't want to go to the "max" adjustment on the shocks, because I have read that you sacrifice ride quality, the higher you set the shock. What has been your experience? Is there that much of a difference, most seem to think the Bilsteins give a better ride than the "Stock" Rancho Shocks, so this may not be an issue.
2. If I only use the adjustment at the 1 1/4" setting, will I see enough of a height change? As I said, I'm looking to get some/most of the "Rake" out, but I'm not fanatical about ending up perfectly level. It just seems that a 1 1/4" adjustment wouldn't be enough since it appears I have a 3" difference to start with.
Unfortunately, once you tell your installer what setting to use, that's pretty much it. If you decide later you should have used a different setting, thats pretty much the whole job repeated, and you end up paying double.
Any thoughts would be appreciated.........I'm new at this "Levelling" stuff, have never done it before, and I'm a bit apprehensive as I have been told by a few "Automotive" types, that you should just leave the thing "Stock" because levelling leads to trouble down the road.
From what I have read here on this forum, there are plenty of folks here with a lot more experience in this regard than me, and I would really appreciate hearing from you.
REV
  • Replies 57
You could always put the front at 1.25" height on the Bilstein's, then swap out the block on the leafs to a 1" shorter block. That would bring the rear down to only 2" higher than the front, relative to stock. And then after adding the Bilstein's at 1.25" you would be close to 3/4" of rake from front to back.
I've never had Bilstein shocks, but I have heard nothing but good things. I would eventually like to swap in a set on my truck.
I had them in my last 08 truck. I liked them well enough. I ran them at the 5/8" setting. By the time I put a topper on it and a set of aluminum gun bed drawers in it, it looked about right.
Spurshot......I see in your sig line that you have a 1 1/2" level kit. It's difficult to see from the angle, but how does the truck sit with just the 1 1/2" adjustment?
From the angle, it looks pretty good to me, so what I'm thinking is If the Bilstein shocks I'm considering give a fairly accurate 1 /1/4" lift on the second setting, that may be all I'm looking for.
I have these on my '09 SLT. Front and rear. When first installed I went with the second up from stock setting. To me this raised the front to much and even made the seating uncomfortable (front was higher than rear). I then had them changed to the first up from stock (5/8s I think) and that was perfect level. Got a lot of complements. Most thought it had a lift.
The truck, to me, drove/rode better too on the first up setting. After 65,000 miles, The truck has settled a little but still no front rake like from factory. Just one of those deals. If you do not like your first choice , yes it will cost to change.
Great shocks and worth the install. They should really take out the harshness I feel on my test drives of the '14s. The Bils are firm and controlled but not harsh/abrupt like the oems.
For the height, park I. Your driveway and jack up the front to each setting and see what you think
Wow!!! just the first step up from stock and your truck was level. Do you know what the height difference between the front and back was before you installed the shocks? I would think the difference in the stock set up would have been greater than the 5/8" you have your shocks set at.
That's whats bothering me........from what I have been reading, and in some pictures I have seen, even though I measure a 3" height difference, it seems setting the shocks at the supposed 1 1/4" mark, will in fact be enough, or in your case more than enough. I wouldn't think the factory "rake" would be all that much different between your '09, and the 14's.
Thanks a lot for your response, you now have me thinking that 1 1/4" should be plenty (Hopefully not too much)
REV
The Bilsteins are out, I picked up mine a few weeks ago.
Sent from my SM-N900V
They don't have any out yet until October for the 2014 GMC/Silverado...What you have is for the 2013...Which bolts up to the 2014 but are not designed for it.
You can call Bilstein usa but I found the first up setting to level the truck. The 5/8 setting does not correlate to a 5/8" fender well lift. No big deal, if the setting you choose is not to your liking, change it. Any good independent shop should be able to do all four installed in an hour to 1 1/4 hour. Changing the setting should take half hour but they will probably charge you a full hour.
The main thing is you will enjoy the shocks.
Thanks for the response.........you hit it right on the head, "The 5/8" setting does not correlate to a 5/8" Fender well lift" .......I wish Bilstein would be more specific as to what (real world) lift you could expect at each of the settings.
I've read many responses regarding the Bilstein's and you are the first that has actually stated that the setting on the Bilstein does not equate to the fender lift you will achieve. It seems in a number of cases, guys were achieving a "Level" result and not having to go to the max settings. (which I was hoping to do)
And you're right, if I'm only doing the fronts, it shouldn't be that big a deal to have them change it at he time.
REV
I hope not!
I had ordered the Pro Comp Series from 4 wheel parts in April, got the rear quick. Waited forever onbtge fronts, then my buddy there told me the Bilsteins, beat them in. So I got those, and having them installed Wed. But I will calling my buddy 1st thing in the am to confirm part numbers... Thanks for the heads up!
TR
  • 3 weeks later...
I'm with you 14'SilveradoLT, I've been chomping at the bit to get these things in and I didn't want to order the model for the '13s knowing that a new version was coming out. I called them a while back and they said end of summer or into fall so I was holding off to call them again.
When you talked to them, did they mention whether you can purchase them direct or do we need to find a dealer? Also, does the new shock have a part number yet?
REV
The rough order of magnitude is 2:1 for the lift vs shock length. The problem is that Bilstein is simply compressing the spring by the amount the collar is raised.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
