New to site 2014 Sierra z71
cgore2014
Just picked up my 2014 Sierra Thursday from the dealership and I love it!! Had the Katzkin leather added and they threw in heated front seats!!! More to come
Welcome to the site. Did they have the Katzkin and heated seats in stock and could I ask how much they cost? Would love to see some pics of the seats. Congrats on the new truck!
They did not have them in stock at my dealership before I finalized everything I had them send the truck to a leather shop to add the leather and heated seats. Im pretty sure the leather was around $1200 and the heated seats were free! ill get some more pictures posted of the interior for you
Welcome. What color did you go with on the skinz?
I went with silver ash with white stitching because thats what the cloth seats were so i decided it would look best keeping it the same!
Surely good seats, what else are coming? Enjoy the board!
They are amazing for sure good quality that i can tell so far. Adding 2.5 leveling kit and 295/55/20 nitro trail graps
Thanks everyone I love the truck so far had it less than a week and a lady backed into the front end so its been in the shop for the past 3 days. Already had windows tinted and while its at the body shop they are putting on the 2.5" leveling kit so will post more pictures when it gets back
Congrats on the new truck. Throw up some photos when you have a chance of the new leather
Here's the front seats. The leather is really good quality way better than expected from my first experience in my 09 Yukon had leather added at the same dealership in 09 they weren't using katzkin at the time and the leather in our Yukon is not near the quality and had a lot more wrinkles in it. This is nothing like last time the day I picked it up there were very few wrinkles and after a couple days they looked perfect so over all if your thinking about adding leather I would only go with katzkin! They also have a warranty on there product not for sure how long but I will look at my paper work and see
  • 1 month later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
