fuse36 Posted October 11, 2014 Posted October 11, 2014 How do I find out where my 2014 silverado was built and what date Sent from my iPad using Tapatalk
newdude Posted October 11, 2014 Posted October 11, 2014 If the vin starts with a 1 its US, if it starts with a 3, its Mexico. I see you have a crew cab, so if it starts with a 1, the 11th digit should be an F (example: 1GCRKSE76EF123456) and would have been built in Flint Assembly, in Flint, Michigan. If its with a 3, the 11th digit will be a G (example: 3GCRKSE76EG123456), and would have been built in Silao Assembly in Silao, Mexico. If you can find one of the customer service reps from GM on the forum, they can take your VIN and get you the details on RPO codes and build dates, or your dealer should be kind enough to do the same.
SouthernSilveradoGuy85 Posted October 11, 2014 Posted October 11, 2014 Send a PM with your VIN # and email to the GM Customer Service account and they will email you the build sheet which tells all of that. I believe it just gave the letter code of the build factory and you just have to look that up, which won't take long. http://www.gm-trucks.com/forums/user/92340-gm-customer-service/
galliher_nc Posted October 12, 2014 Posted October 12, 2014 The sticker in the door will tell you what month and year it was built. It will also say either "manufactured by general motors de mexico" (or something to that affect) and if it was built at Flint, it'll have a little decal in the door that says something like "world class people make world class trucks" and it has the state of Michigan and a UAW logo on it as well.
fuse36 Posted October 13, 2014 Author Posted October 13, 2014 I found the window sticker says Mexico but says engine and transmission United States. We're all motors and trans built in US? Build date was 2/14 Sent from my iPhone 6 using Tapatalk
galliher_nc Posted October 14, 2014 Posted October 14, 2014 I found the window sticker says Mexico but says engine and transmission United States. We're all motors and trans built in US? Build date was 2/14 Sent from my iPhone 6 using Tapatalk Yes.
junkyardz Posted October 27, 2014 Posted October 27, 2014 build date of 08-2-14 on my 2014 sierra, via sticker on driver side frame rail
Donald Tomlinson Posted December 31, 2019 Posted December 31, 2019 How do I get a build sheet to my new 2019 Silverado? Don
davester Posted December 31, 2019 Posted December 31, 2019 Well, 19's can sometimes be jittery, so your best bet is to sneak up from behind the truck, but off to the side a bit (it may try to suddenly reverse over you), crouching down, and then as you approach the driver's side door, spring up and slap the build sheet onto the window. And that is how you get a build sheet to your truck.
wforrest08 Posted December 31, 2019 Posted December 31, 2019 2 hours ago, Donald Tomlinson said: How do I get a build sheet to my new 2019 Silverado? Don send an email to [email protected] with your vin requesting a copy of your build sheet. should have it emailed to you within a couple business days. if you didn’t buy yours new you can also request a copy of the service records. this will show any service/recalls that was preformed at a stealership.
