Black trucks
2014 SLT 1500 an the left and 2015 Denali duramax on the right. 20,000 miles on the SLT and 5,000 on the diesel and so far no issues at all. SLT has 4 inch lift, wheels/tires and amp steps. Denali is torsion lift in front, same tires/wheels as the SLT and now amp steps. Really like the amp steps, a little pricy but so much better than the nurf bars. Very nice trucks!!!
  • Replies 31
Good looking trucks! You can't beat a black truck when it's clean....they're just really hard to keep that way, haha. So it looks like the 2500HD with a little t-bar crank sits about as high as the 1500 with a 4" lift, right? Got any more pics?
Only 1 more pic. Yes black can be hard to keep clean but in my area every other truck on the road is white.
The 2500 sits about 1" higher than the 1500 with a 4" lift.
Nice trucks. Like the black a lot. I live off a gravel road so it's hard for me to keep one clean.
What make and size tire did you install on the HD and the rim size. I am installing a ready lift level kit on mine and will be looking to go up in tire size.
285/55R20 The Nitto-All Terrains are surprizingly quiet.
This a farm truck so in dust all the time but not to bad keeping it (sort of clean).
I loved a black truck right out of a car wash. I live on a gravel road and by the time I got the clean truck home it needed washed again. I gave it up for a same model truck with a color that looked cleaner longer.
I'm looking to upgrade the wheels on my HD...What size tires and rims are you running and did you make any suspension mods?
Silverado LT 4x4 Z71 Double Cab with the 5.3. It's basically going to stay like this for awhile. If anything I want black rims (Rockstar 2s XD811 18") and maybe match the front tint to the rear door tint. Also want to add the Airaid MIT intake tube.
Looks good are the tires on the 1500 the same size 285/55/20 as the 2500?
No. With the lift on the 1500 I put (305/55R20 ). Was worried about rubbing so down sized slightly on the 2500. Neither of the trucks have any rubbing issues.
Here is my Black Silverado after a wash ....
Sorry to cut in uninvited but...
You wash your truck?! Isn't that consider blasphemy? :-)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
