No, no you can't do that. You have been given a mission to remove the rear bumper my friend. I must know how lol. I want to pull the bumper at a later date when I get it colormatched and also so I can pull the black plastics off and bed line them for better grip and so they don't fade overtime.
Edit:
Just found this after searching real quick
http://www.hammerheadarmor.com/wp-content/uploads/2014-CHEVYGMC-1500-REAR-BUMPER.pdf
So many small screws I have to get to. GM made it so you have to take it to the dealer basically lol. I'll get back at it another day I'm sure
You must haha. And yea. They seem to have made this truck a PITA to take apart some things. Probably trying to keep people like us from messing with it. But little do they know that they can't stop us [emoji106]
  • 5 weeks later...
Didn't need an oil change just yet, but I've been towing quite a bit frequently and I'm also going on a 500 mile or so trip to Hatfield-McCoy which requires me dragging a trailer with three quads on it through the mountains so figured I'd do it now. Also dropped the trans pan to clear out any break in shavings and clean the magnet. Magnet was full (sorry no pic). Still need to do the tcase and rotate the tires this week before I start loading Wednesday night!
Current mileage is 14,3xx mi. in case y'all were wondering since I put on some insane mileage here lately with the new truck lol
Update: rotated tires right after I posted this [emoji23]
Edited by rdnckhntr94
Cleaned her up today in prep for my trip:
Also installed a BOLT receiver lock yesterday. Very high quality and highly recommend one to everyone
I love the bolt lock. I het to spend a weekend with josh criticizing my truck and california driving.
Just ended my 800 mile round trip towing about a 3600 pound trailer, 400 pounds of gear in the bed, plus the truck had 4 full sized adults in it. Worked it up and down the appalachian mountains. She was working but she did awesome. Down hill assist is a life saver on these 6 speeds. Helped save my brakes for sure
Towing up hill in 2nd gear working hard
My other baby [emoji7]
She got 12 hours of riding in and 132 miles. You can say I'm beat lol
Found the truck i really want at a lodge up the street from where we stayed [emoji7] [emoji7]
Had a ton of fun and can't wait to go back now!
  • Like 4
Do you have a half ton AND a 3/4 ton high country!!??
Edit: oops, i think I understand now, you saw one you liked lol, my bad!!
Edited by morrislee
No mods lately since I've been getting my other truck ready for the road, but I am taking the boat out tomorrow with some friends and they have boats as well. You can say it will be a redneck yacht club lol
Lol. It's mainly stock as it sets Zach! Not sure if I want an exhaust system or not now. Love how quiet it is
Thought of you when I saw that and felt like sharing lol
Finally spent some time cleaning the truck up a bit. Took bug and tar remover to the grille and the headlights to clean up all the stuck on bugs:
Looks better than when I picked it up at the dealer lol. Need to hit the front bumper as well, then behind all the tires. Gonna have my buddy do a clay bar, compound, and wax before fall comes around (I'm too lazy nowadays).
Also noticed this the other day [emoji50] [emoji26]
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
