33 minutes ago, Kurtj29 said:
PM sent. Looks great. I am interested in your Denali grill. I have been going back and forth between doing a black out Denali or the standard grill. I purchased an SLT grill and was going to wrap the chrome surround. But lately have been looking to do a blacked out Denali. Thanks for the pictures.
Thanks. Replied to your message.
On ‎12‎/‎4‎/‎2018 at 8:47 PM, Kurtj29 said:
Good looking truck, where was the picture taken?
I usually do a full detail when I get a new truck but haven't had a chance yet and the NH weather has been crappy, but I picked up my 2018 Silverado LTZ on Thursday this week.
I'll post better pictures once I get it cleaned up a bit.
Thanks, the picture was taken at Keechelus Lake up at Snoqualmie Pass, Washington.  Just take the service road out past Snoqualmie East.
Approximate location:  (47.3767460, -121.3887877)
Edited by Kurtj29
Kind of thought it was up at Snoqualmie, you can see all of the stumps in the lake behind your truck. Wife is getting heavy into photography, so we have been going up 410 to Crystal, snow is piling up pretty good.
57 minutes ago, CruseMissle said:
All-Terrain in a little snow
Great picture!
Edited by Kurtj29
Went out in the rain on Friday and got a couple of shots.  Trying to make something out of the cold dark winter day here in the Northwest.
0666FE5B-EE73-40E0-8E81-A877A6090F03.thumb.jpeg.43bde476a7713cf5c1a34a2c8f69c382.jpeg82A33821-A489-4381-8266-595F2E37E295.thumb.jpeg.117e46b06b5c7ff6774669b9b854783c.jpeg
Edited by Kurtj29
That is a great photo of a good looking truck!
Good looking shots of the truck, espically the bottom picture.
First time post, I've been watching this forum for years.
2018 GMC Sierra SLT.  3/1 lift, 35 inch Toyo Open Country tires.  T-Rex black grill inserts, then popped on a Z71 emblem I bought on eBay.
Installing ICI Magnum RT steps next week.
Any other ideas?
Any other ideas?
Welcome, nice looking truck!
5 hours ago, slj2008 said:
Welcome -  Window Tint (if you haven't done it) .
I haven’t.  Front and back windows or just front to match back?   Rear window?
On 5/6/2018 at 8:02 PM, RK44 said:
FInally got the ARE overland cap w/yakima racks and bedrug installed.  Mods include Fuel Maverick 22x10 -24 offset, Terra Grappler 285/50/22 (33.26"), ICI magnum RT steps, Black Horse Grille Inserts, 20% tint all around and a 5% brow.  Motofab 2.5" Level/lift and Zone 1.5" body lift, husky liners on rear wheel wells.
How are you liking the ICI Magnum RT’s?   If you had to estimate, how far are they mounted from the rocker panel?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
