2014 Sierra All Terrains 1st snow
Tattooo
Don't have an AT, but I can't wait for it to snow. I already love driving in snow, but I want to try the truck out in the snow and see how the auto 4x4 does since this is the first truck I've had with auto 4x4 (normally keep it in 2Hi).
It wasn't bad enough to need 4x4 but like you i keep it in 2h & its my 1st truck with auto 4x4 & i cant wait to see how it works as well ...
Ya there's a ton of big hills around my house which would be nice to have the auto 4x4 when it's melting. The way it is around here, the main part of the roads seem to melt first and then the intersections and hills. So would be nice to have auto 4x4 for those areas so I don't have to keep it in 4Hi the whole time when it's not needed the whole time.
We've had snow for a month already. I've plowed at least a foot of snow with my truck in 4 Hi with my Goodyear SRA's. I'll admit they aren't the greatest but they aren't the worst I've had.
If you need to plow snow, take off the plastic air dam below the bumper.
Yeah, works great in snow. I live in the boonies outside edmonton here and the 30-50 cm of snow got me stuck backing out the very first day. switched to 4x4, drove out like nothing happened!
White all terrain here ;)
We had snow but not enough to have to much fun.. I did punch through a few drifts..
I did have to go out in the freezing rain and the 4WD was great on the ice.
The truck should be insane with better tires.
My truck is great in the snow. I have general grabbers and they live up to their name.
my air dam is sitting on back porch!! went through low spot on dirt road slow and it tore the air dam off at several mounting bolts, the older 07 and 11 air dam was a softer plastic and would flex out of the way not on the 2014 it tore it!! tough with the poor ground clearance of the chevy 4x4 trucks
Was told the air dam is not really needed till you tow in hotter weather for proper air flow into the radiator, anyone heard of this situation?
Thousands of people have removed them, your truck will not blow up
Ryan
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
