Yep, I get it. Mine is a Silverado LTZ, but just bounced a lot. Much more controlled now. I don't even have to slow down at railroad crossing any more. Wife used to say the truck bounced so much that it made her feel like a "bobble head". No more...much more smooth and controlled.
Did the rear install myself. Dealer installed my fronts and aligned for $300.
Thanks man.
Funny you mentioned railroad crossing. I went over a railroad crossing in the 2015 loaner and compared it to my 2014 this morning, and it was way rougher going over it with my 2014.
They definitely changed up the valving or something on the All Terrain shocks from 2014 to 2015. Both trucks are nearly identical. The 2015 is a crew cab though, my truck is a double cab. But both have all-terrain Z71, 20" wheels/tires, same air pressures too.
Looking forward to the Bilsteins for sure.
I had set of the 5100s installed on my 2010 Sierra ext cab with preload set at one down from the top setting lifted front up think about 3/4". Just my opinion it really lost any ride quality very rough any bumps the front suspension did not react at all just pounded the front. Another $300 had the spring settings set at the factory preload another alinement rode much better suspension working as designed smooth. Guess i felt dumb paying hundreds of dollars and having the truck just pound it self to pieces because the front springs were preloaded to much. I now have a 2014 would never do the lift thing again.
Yea, I don't plan on lifting the front end. Gonna put the shocks at the factory height settings.
Lmao, you'll laugh, but I went with the 5100 over the 4600 because of the color of the shocks. I thought the blue/yellow of the 4600's was an eye sore compared to the 5100's black/silver.
Edited by fondupot
I wanted the 4600's, but they weren't out yet, so Bilstein recommended 5100 for same price at the time. My 5100's are at stock ride height too.
I agree, The silver is kinda snappy with the black boot on the back installed downward.
Edited by chuckl1218
So, the ride quality is the same between the 4600 and the 5100? I have a 2015 crew cab with the Ranchos and I hate how bouncy they are. I don't want to change stance, just want to improve the ride quality.
From what I have read about them. Yes they are basically the same exact shocks. The 5100's just have the option to adjust the spring perch to give front end lift.
Bilstein actually reccomends not using the 5100's at the factory settings, well at least that's what they told me when I called them. I'm sure it doesn't make that much of a difference though, that factory ride isn't hard to beat. I was going to leave mine at stock until they reccomends otherwise. The silver def looks a lot better than the blue and yellow though.
Yep, that's what I was told by Bilstein and Allshocks.com (where I bought mine from)...
More Pichers!! I'll be trying to get mine installed Wed or Thurs.
Local Gateway tire quoted me at 203$ to install all four shocks and align it. Seems incredibly cheap.
Use caution on the alignment....after reading about the steering wheel angle sensor alignment requirement (for the electric power steering to correct for road crowns) I started asking local shops if they had the ability to do that procedure. In every case I was told no. So I ended up at the dealer.
Then i'll be going to hefner motors in batesville, they're a dealer. Quoted me 300$. Can also ask about the windsheild. Which has a 12" crack on it.
Gotta take measurements when I get home. Here it is though 414$ and 3 hours later.
Just had the 5100s installed yesterday. Went with one click down from max height setting on the front. Ride is MUCH improved over the crappy stock Ranchos. I feel like it hits the potholes, railroad tracks, etc with less bouncing in the seat compared to the stock Ranchos. Just feels tighter and more controlled on the road, with still being smoother than the Ranchos. Very happy with the outcome.
Got a great deal at streetsideauto for $308 shipped. Paid $400 for installation of all 4 plus the alignment - a bit higher than some on the forum but it's a local guy that I've had work on my cars for years and I trust his work.
I'm now sitting at 38" front wheel well to ground, and 39.5" rear. Looks way better IMO.
    • I have 2 choices.
