Got a 4.3L V6? Use E85 !
Don't buy a CAI or one of those eBay chips to make your car faster, run E85! I've been using 91 octane from Chevron for a little over a year now and finally made the switch to E85, the performance I got from simply running E85 was more than I've ever gotten from running a CAI or SRI on a naturally aspirated engine.
Yes it's that good.
Placebo? Doubt it. Not sensitive to that stuff...
So give it a shot! Try it out and report back!!
  • Replies 31
I've wanted to try E85 in my 5.3, but there isn't any stations that sell it anywhere near me.
That's a bummer, I work in Long Beach and used http://propelfuels.com/ to find the nearest station with E85, found the closet one ( 5 miles from work ) on PCH in Wilmington. Nearest station with E85 from home ( Whittier ) is La Mirada and Norwalk, which is about 10-15 miles away. It's a mission just to get the fuel, but worth it if it isn't too much of an inconvenience.
Well the closest one is 50 miles away so that's a no go for me, at least until they put some closer.
I have burned several tanks of E85, it's readily available in the Midwest because we grow a ton of corn here.
It bumps hp from 285>>297, and torque from 305>>>330 on the 4.3l, which is a lot more benefit than you could get from a CAI. You'll buy 20-30% more gas, but at the $2.00-$2.50 a gallon it costs these days at least it's not such a bad deal to get 13mpg in exchange for the extra kick in the throttle.
(and you know your fuel money stays in America and employs Americans, helps wipe out our dependence on foreign oil, and is renewable)
About the only downside of the stuff is it's subsidized, but gas is indirectly as well by very low taxes.
Not dependant upon foreign oil out here. The oil we pump into our cars here in the west and mid-west comes from the good ol USofA. And yup, I do run a few tanks of E85 a year in my flex-fuel car with the GM 3.6L in it, and it does make a noticable difference. Probably not as much as it does on the trucks though.
Enjoy that sweet Kern crude. Cant use the oil we produce here. It is too dirty and thick as molasses.
Now I really want to try it. I work in downtown L.A. so I'd have to go a little out of my way to get to a station. I've had my '14 GMC 4.3L for about a month, only filled up 2 tanks since delivery.
Would be interesting to see if there is any difference in power so early in the life of the engine.
Thanks for the update @arkenzo.
Curious as to why you guys were running 89/91. Performance only? MPG suffers and higher cost also though correct?
My understanding with the 89 and up octane is that if the engine is designed for 87 then running higher octane won't help it any. I say run what the engine is designed for. Of course if it's tuned or is forced induction then that's different.
Mine as well, which is why I'm curious. Unless you gents have your trucks chipped or tuned?
GM has fuel sensing and changes the tuning of the 2014 5.3L when it detects the E85.
There are GM published figures for the higher horsepower levels for the 5.3. I have never seen published numbers for the V6 (so don't know if it has dual tuning or if it is placebo effect)
For the 2014 5.3L these are in the Sierra brochure:
355Hp @5600rpm on 87 octane, 380HP @5600rpm on E85
383ft-lb@4100 on 87, 416 ft-lb @4100 on E85
for the V6: 285hp@5300; 305ft-lb@3900;
In the 2015 brochure, there is no mention of increased HP with E85.
For 2015, Flexfuel capability is std on V6, OPTIONAL ON 5.3L, and still not available on 6.2L.
One of the Mags. showed a 3 tenth 1/4 mile gain with the 4.3 on E85 to 15.7 from 16.
I'm not talking about E85. I'm talking about regular 87-91 octane. My 5.3 is designed for 87 and E85, so if I filled up with 89 or 91 octane then there won't be any difference in performance. On the other hand, if an engine is designed (or after tune) for 89 or 91 and you put in 87 I believe it will lower the performance from what I've read. So all in all, just put in what the engine is designed run on. It's that simple.
"for the V6: 285hp@5300; 305ft-lb@3900; "
Those numbers increase to 297hp @ 5300, 330ft-lb @ 3900 with the V6 on E85, makes it drive a lot like last year's 5.3l on E10.
(which had 315hp @ 5200,335ft-lb @ 4000RPM)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
