Paint stick with a little 3M double sided molding tape to hold it under the bracket without slipping out is the practical solution.
Just did this today. Truck is much more responsive. Thanks to the op and the other responses. I used a paint stick but needed to pieces stacked together. I'll throw some double sided tape on it eventually.
I did this last week with some 3/8" wood stock. Much better throttle response. I don't care what the engineers think, this is better!
Edited by F4Gary
After finding this thread, I checked the pedal on my 4800 mile '17, and sure enough, there's flex. Seems the issue was never addressed; while there wasn't as much flex as in videos posted in the thread, I'm sure that would change as the plastic fatigues. Unbolted the pedal assembly, jammed some cedar shingle shim up in there, tightened bolt back down on it to hold it. I've noticed a marginal improvement, due to there not being much flex there to begin with.
/de-lurk
This is very fascinating. I wouldn't say GM's approach is wrong, but it prioritizes things oddly. My 2016 6.2 adjustable pedal denali has a wiggly pedal. Yes, it never buzzes or vibrates, but I would enjoy it more if it were more solid.
Here is my question. With the heavy carpet and sound deadening and the adjustable pedal in the way of the third bolt... How did you'all get behind the floating mount to shove something? I can't 'get there from here'.
Thank you in advance
WL
/re-lurk
I'm glad I found this thread. Just did this to my 17 all terrain. World of difference!! I love it
Great INFO !! I have a 17 All Terrain coming in about 6 weeks I think I will drop off a piece of paint stick with the Service Mgr and tell him to install during prep :)
He's actually good guy he agrees with a catch can install saw in on my 2010 tild me he has ine on his persimsl truck " no issue eith warranty"
I was intrigued by this thread and did some poking around with my Sierra. Lots of flex coming from the plastic bracket that the pedal mounts to (red arrow). I couldn't find anything around the house to shim it with due to the tight area. I'm planning on getting some dense rubber, like a chunk of PVC pipe coupling, and wedging it behind the plastic bracket. (yellow arrows)
I hope you truly don't believe what a Service Manager at a dealership has to tell you because if you do then I feel for you if something bad does go wrong with your new truck. Dealership guys come and go and when it comes to GM actually paying to fix a problem then they will buck if you have altered your vehicle. I am not against the catch can, exhaust, programmers, etc but anything that you put on that alters the way GM designed the truck then you may have problems when it comes to warranty.
I just shimmed my 2015 Silverado gas pedal and it's a world of difference!! It was wiggling around as I drove it was so bad. It made the transmission seem like it operates much better now. Weird I know but I highly recommend this to anyone who has even the slightest flex in their gas pedal!!!
Sent from my E6810 using Tapatalk
Service Manager = Idiot more often than not IMHO!!!
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
