diggman08 Posted December 31, 2014 Posted December 31, 2014 hey guys, if my key is turned all the way to on position, but not cranked the check engine light comes on. As soon as I crank the truck, the check engine light goes off. can yall do a test and see if the same results occur, thanks
nards444 Posted December 31, 2014 Posted December 31, 2014 moat vehicles I have had in the last 15 years the check engine light would always flash,or illuminate for a second upon start up. normal
newdude Posted December 31, 2014 Posted December 31, 2014 Completely normal. Just an instrument cluster self test/vehicle self test at key on.
Btuggle88 Posted December 31, 2014 Posted December 31, 2014 Normal it kinda lets you know all the lights work just in case they need to come on, if it never comes on you should worry.
POS VETT Posted December 31, 2014 Posted December 31, 2014 All vehicles with electronic powertrain control do this.
diggman08 Posted January 5, 2015 Author Posted January 5, 2015 all the lights do come on as a test, but then go off briefly after, but only the check engine light stays on, until cranked, then goes off. just wanted to clarify that. still norm?
Btuggle88 Posted January 6, 2015 Posted January 6, 2015 Yep still normal only abnormal if it stays on after its running.
BigBadSierra Posted January 6, 2015 Posted January 6, 2015 Light comes on. You start the engine. It runs a quick diagnostic check on the engine. Then the light goes out.
