Yes, that switch would work but the Exhaust Brake uses the other connector on the back. You likely have some wires plugged into a “blank” on the back of your switch now. The exhaust brake has 6 pins at that plug, two of which are used for our purposes. The exhaust brake plug and the main plug use different terminals. You could easily cut and splice but this switch might be better suited as you can just relocate The HDC terminal to the cavity on the main switch plug that corresponds with the CNG pinout. Unfortunately I don’t have a diagram for that but it’s easy to find which one that is using a multimeter. (Assuming it doesn’t use the same plug as the exhaust brake). I have only seen this switch on eBay but it’s around $30 US.
Obviously you wouldn’t have the right size HDC button cap for that switch. I’m waiting on my BCM to come back from White Auto & Media so I’m going to say hold off on the X50A until I can test the one that I just got in my “15 6.0 just to be sure it’s compatible. I do have a couple extra HDC button caps and I’ll gladly mail one to you so you can use the CNG one for your slip tank in place of say AUX 4. I’ll get part numbers for terminals together soon to save money over buying terminated leads through GM.
Stoked to see the video of this.
Will be doing this mod next month.
Do you happen to have the info on how much we can plug into these new relays - max amps I mean.
Will be using mine for light bars and air compressor.
I'd really appreciate that, TF. That switch bank looks like it would work perfectly. Do they typically have a master harness feeding into the back? Or does each switch have its own plug?
Has this gotten a successful review? I’ve been pondering the idea. So these switches are switched negatively so if I run my own relays and switch with negative instead of a 12v these should work?
Each switch has its own pin-out in the main plug that plugs into the switch bank. The exhaust brake uses a separate plug that is a blank on a truck with a gas motor. If you have a truck with T/C, Cargo Light, and HDC and you plug in a switch with those options plus a few more, your options will still work and all switches will be illuminated with the dimmer but the extra switches will be sending a signal to an open cavity in the main plug. (No wire will be present in the plug) I haven’t had the opportunity to test a panel with CNG but I assume it sends the signal through one of the pins in the main plug. You would locate that pin on the switch and move the wire in your plug corresponding with HDC over to the cavity corresponding with the signal from CNG. On switches that have an indicator light there will be a second wire coming back to that switch as well. Upfitter switches don’t need a second wire for an indicator light as the switch will stay closed (like a clicker pen) until pressed again. Since HDC has no indicator light and CNG does you would not utilize the indicator light and have to slightly modify the inside of the toggle cap (the part that disperses the light) as it will slightly contact the indicator LED. It’s just a little trim job on thin plastic.
Did I see someone make a plug already pinned out ? I currently only have 3 stock buttons. I got a aux gm one with the cng button. Does someone make the plugs needed to switch my own relays using grounds like I read?
I just tested an Upfitter switch with a CNG button (23146445) and it seems to be identical to the one with TC,Cargo,Exhaust Brake (23145163?). The output and indicator input use the Exhaust Brake plug (X2). If you were to use this CNG switch, or the Exhaust Brake switch inyour application you would need to remove terminal/wire 4 from the X1 connector (main plug) and swap into pin 4 on the X2 connector (exhaust brake plug). The terminals are a different size so a cut and splice would be necessary or just replacing the terminal. This would allow the use or triggering of HDC through the Output pin from CNG or Exhaust Brake. You would just pop on an HDC cap in place of CNG, then move the CNG cap to say Aux 4 to use as your slip tank Trigger.
Edited by TinkeringFox
Upside down pics
I believe the relays in the new X50A are fused at 30A. You could also just add your own relays without the new Underhood fuse box (X50A) and just use something a little beefier like 70A Hella relays.
I posted this earlier in the thread but will bump it again.
Switch Fuses 5Amp (only 2 of the 4 spots should end up being populated depending if you want them to work with the truck off.)
-22 Aux Switch1+2 battery power
-26 Aux Switch1+2 switched power
-27 Aux Switch 3+4 battery power
-31 Aux switch 3+4 switched power
Power Fuses 30A
-23 relay for sw2
-30 relay for sw3
-32 relay for sw4
-37 relay for sw1
Relays
-60,61,62,65
I found it much easier(and cheaper) just to use the upfitter switch and run my own relays.  I'm running a 50A main wired with 8ga  to 4x 30A relays fused at 20A with 12ga wire to the loads.  Got a 6 pack of the relays off amazon for 27$
Did I miss how to get a plug for this switch set. My truck has stock 3 switches. I bought these switches but need some sort of harness to be able to use these. Can someone point me in a way to get the plugs for the back?
I didn't need a extra harness for mine, I just put the 4 new pins in the existing harness but I believe Tinkerfox above posted the documentation for the extra plug needed for the CNG/Exhaust break upfitter switch.
In my case(only TC and bed lights) I removed the 4 factory wires (the y,r,gry,blu striped wires on the right) and repinned them with the ground side of the relays coil.
OEM connector 15488869
Edited by Crazyjoker77
Which three buttons did your truck originally come with? I’m assuming TC, Cargo, and ?
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
