Rigid Fog Lights - D-Series DOT/SAE Certified
ktech35
I just thought I'd share this, as yall know my HIDs failed last weekend and so yesterday I had nothing to do so I worked on the truck, one thing I did was put the halogen bulbs back in the headlights and I am hardly even using them. The DOT pods are more effective than the OEM projectors with halogen bulbs.
Just thought I'd share this find with yall!
  • Replies 227
Has anyone heard when Rigid Ind is going to release the pod mounting brackets for the 2014 Silverado's..???
Soon as it's released I am outing these in!! Can't wait..
Not sure, but I know it should be released soon
http://www.rigidindustries.com/mounting-options/46517
I'd give them a call or shoot them an email and see what they say.
Getting the Rigid DOT pods installed as we speak! i'll try to post some pics of output tonight. i didn't get any pics of the OEM fogs before, sorry.
Yeah I want to install some as soon as they release the bracket. Anyone know what light this is supposed to mount? It would be awesome to buy the lights now and then order the brackets when they come out
Very clean install! Love the look! Ready to see the output!
Well??? We waiting... lol
2015 Denali 3500 DRW, Michelin ltx, 4x4
Exactly what I am planing to do... I sent a Rigid an email so let's see what they say.!
I did the same thing right after I posted lol
Just curious how many are interested in purchasing a set? I was thinking about contacting Massdrop for a group buy... perhaps we can get a better price than $265...
Edit:
What the hell, I started a Poll to vote on Massdrop. Here it is; http://dro.ps/v/HrATTsh
Well here ya go fellas. First off these things are very bright! I was not disappointed at all! On my way home I was flashed one time and that one time was by a semi... might not be a good thing. I may try to adjust these down a little more. I could see every face in the cars i passed. My wife was in front of me and said they were pretty blinding... I love the brightness but I don't want to blind people. They almost wash out my headlights all together. If you're not sure about getting these, just get them and don't look back! here's some pics
Those signs are about 50 yards away. The first pic is rigids only.
Rigids with low beams.
Rigids with high beams
This is rigids only about 10 feet away from my garage.
You were probably blinding them because you got some serious Carolina squat going on. Your lights are pointing up haha
Lol I've got to change that pic. I have no squat in the truck. I did in that pic though. It was on a hill and had weight in the back
Oh ok haha. Not a fan of the whole Carolina squat thing. It looks like a dog dragging his ass on the ground hahahaha [emoji23] [emoji23] [emoji23]
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
