The bump stop cap is different. That's the large metal cup thing that slides down over the top of the shock. I'm missing a tiny snap ring that sits in a grove near the top of the piston rod.
My bad. I see the part you're talking about now. Either way, call Bilstein and they'll send you the right piece.
Are there any companies like carli or thuren that build high end kits for chevys? Coming from a dodge and there isn't a lot of competition for carli or thuren components.
Give Bilstein a call and they will set you up!
Here are the install directions if anyone needs them - http://cart.bilsteinus.com/pdfs/E4-WM5-Y458A00.pdf
Baja Kits, Camburg, Dirt King, Mazulla, etc.
Called Bilstein first thing this morning. The shipped out the missing circlip ring. They told me that little piston rod snap ring holds your top hat in place, so it is necessary!
First off your truck is designed to be used so do what you want with it
Sent from my SM-N920V using Tapatalk
That is a beautiful truck. I wouldn't go so black but wow it looks good
Got mine from shock warehouse. One came without the hardware. Shock warehouse wouldn't return emails or calls. Had to get another shock from somebody else. when I called Bilstein they said they couldn't take the one back with no hardware as they didn't sell it. Shock warehouse still won't respond. The shocks are nice however. Ride much smoother than the rancho's.
Edited by dusty280
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
