I replaced the black stock shocks with Bilsteins. I like to say the ride is more controlled now. Less shaking and bouncing with the Bilsteins. My wife used to say she felt like a bobble head when riding with the stockers, but not now.
Good to hear, yeah my wife and sister both commented on ride on bumps. They didn't know how to describe it but knew what they meant. What setting are you on?
2nd from bottom (1 up from stock). I didn't care about "leveling". Just wanted a better ride.
Edited by chuckl1218
Thanks, I'm after both want a to leave little rake but not as much as stock. Hate nose high look. I'll try top setting and see how it goes.
My guess is that you will be happy with the top setting. I was thinking the second from top would be a bit of a compromise on the firmness issue and I was originally planning on a 1.5" lift. However, I sincerely doubt there would be any difference in the ride except in one's imagination. The difference in looks would be hard to notice, but just knowing that extra little bit of lift was unused would probably annoy me for a very long time!! If I go Bilsteins, I believe the top setting is the one to use. I suspect that most people use the stock or top settings on these shocks and that the in-between choices are more for marketing purposes.
I just installed a set on the second setting on my truck today. I'm still running the factory goodyears and I didn't want them to look out of place. They gave .75" of lift as advertised. When I get new tires, most likely 275/60R20 or 275/65R20 I'll go up to the third setting. Ride is much better; I'm not bouncing all over the place now. Lift is noticeable to me as well, which is the most important thing lol.
Does anyone have a pic of the top mount of the 5100's when they're on the vehicle, or can someone go take one? I torqued the top nut down to Bilsteins measly 25 ft/lbs, and that doesn't seem right. The top spacer right under the nut can spin when the weight of the vehicle is on it. The last set of these I did, on a Titan, had a definite stopping point.
I have currently the Rough Country 2.5 lift/level kit with 275/65/20 cooper at3. The ride is ok. I did put bilstein 5100's on the rear which helped a ton! but the front is stock. I ordered a set of 5100's for the front. I'm trying to figure out if I should leave the kit in and run the front shocks on the stock setting or should I set the shocks at the .50 setting and run the 2" lower spacer...? Or run the shocks at the highest setting and run the 1/2" upper spacer...?
I had the same dilemma....RC 2.5" kit which gave me 2.25" of actual lift over stock.
This weekend I installed the 5100's all around. I put the fronts on the top setting, took out the lower spacer and left the upper spacer in place. End result is a true 2.5" of front lift. I haven't driven it a ton yet but ride is already improved.
If you are going to put the fronts in yourself...give yourself some time...its not a quick job.
Thanks for the info! Did you leave the rear RC block in or put a larger one in?
I had switched out the 2" block for a 3" block when I ordered the kit.
So now have 2.5" in front and 3" in back...looks pretty good IMO.
Ok did u need new UBolts or did you just swap the block ?
    • www.enginelabs.com/news/what-i-learned-today-bearing-clearances-vs-oil-viscosities/
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
