Chevy disses new aluminum body F150
Duallies have been "non-metal" for quite a while.
At least just the ones with a separate extended fender. For years those seem to be fiberglass. Now they're starting to make the whole fender one piece.
  • Replies 44
At least in the 800's the whole single piece dually bedside and quadrasteer bedsides were composite.
GMT-900 and K2 both are one big slab of steel with the dually fender formed right into it. So, GM hasn't been non-metal dually since 2007.
Starting on the early 800's the dually fenders weren't steel, that's what I meant by "for a while". I have no idea on the newer ones, haven't worked on one.
I could honestly care less what they make the body out of, regardless of who makes it. I just think that most of the vehicles on the road just aren't set up the way I like them or they are uglier then sin. After all I went from a 9 year old truck to a 15 year old truck just last month.
I'm just wondering how easily the new aluminum body on the f 150 will dent
Too be honest, it can't be any easier than what GM uses on their trucks right now since they use pretty thin body panels. I love the truck but I don't like how you cna literally push a finger on the panel and see your finger able to push in. I know it's to save weight and the body panels don't save you in an accident, I'm just used to how the body on my last 2 Chevys were more normal.
Ive owned a Saturn. It was great. The salesman sold me on the car by kicking the drivers door on the first one he showed me as hard as he could. Never got a door ding. I HATE door dings.
My daughter is still driving her 2004 Saturn Vue Redline AWD Electic Lime with a Honda 3.5.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
