New Shocks... Again...
GMC-AT
I just got new Bilstein 5100 installed... not real happy with them....too stiff. Thinking about getting them replaced. What would a good softer replacement shock be? No lift company shocks... something like a Monroe?
I drove a stock GMC Sierra SLT non Z71 before I ordered mine. Seemed a lot better then my Denali Z71 but not sure if it was the 18" tires. I too am looking for a much softer ride. I'm thinking I should just find a dealer with a non Z71 WITH 20" tires and test drive it. GMC-AT maybe try that as well.
Monroe and Ranchos are the same just FYI. If you didn't like the ride of your stock All Terrain with Rancho shocks...the Monroes won't feel any different.
Bottom line, its a truck its gonna ride a little rough.
If you can pony up the money, I've heard Fox and King shocks ride nicer. I'm looking at going with Fox 2.0's on all 4 corners of my truck.
Hi GMC-AT, I have looked at the rancho quick lift too. Everybodys opinion is differant about a soft ride. I have read where some love them and others hate them just like you found out about the 5100's some like some don't. I was thinking about just going with the shocks that come on a regulat 4x4 not z71. My only problem with the stock ranchos is town driving you fell every little bump in the road expansion joints fill to stiff almost on some fills like the front end comes off the ground. I like a little soft bounce in a truck.
Maybe it's not the shocks, but maybe the tires. If you are running stock tires on a AT, 275/55/20, that's a short sidewall and will ride stiffer than a tire with a bigger side wall. Upgrade to a 275/65/20 and run them with 5lbs less air pressure than you normal would, and your ride will be 20x better
I have BFG KO2 275/60/20 ... running at 37psi.
Gotcha.... sounds like you know what you want.
My '15 AT rides better than my '05 Silverado Z71. So I'm not complaining about the ride...... yet
Lower the PSI to 34-35. Yea, you may lose a few MPG, but believe it or not, it helps tremendously with the ride comfort. But those KO2's I'm sure are a lot more stiff than stockers so they are bound to be more rough riding.
I think you're making your next selection based on price. Buy a couple more sets and you coulda had Fox or King.
The psi in a tire makes a tremendous difference. I had a cj7 with 31's, ride was very stiff. Just lowering the air pressure a few psi made the ride so much softer
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
    • @OnTheReel , What oil was used for this sample?
