got the truck leveled with some new tires.
2018 GMC Sierra 3500 with 325/65/r18 Duratracs (34.6 x 12.8)
weather is terrible driveway is just snow so i just snapped a pic when i was leaving the liquor store... lol
I like!!
Sent from my STH100-1 using Tapatalk
You were able to put those 325 65 18's on stock wheels? No rubbing on the upper control arm?. Had those tires on my '16 and loved them, quiet, smooth.
hey Gearhead,   i was just under the truck yesterday double checking clearances, with my wife holding the steering wheel each way, there is no contact on the UCA nor anywhere inside the wheel wells themselves  BUT at full lock it does rub against the sway bar, considering 1/4 inch wheel just to give a little bit of clearance... but might just let it ride...  it's only at full lock so i am not sure if i should space it the 1/4 inch or call it a day and keep that 1/4 inch extra on my wheel lugs instead...
What offset are your wheels?  I have 20x9 Fuel +1 wheels on my 2017 2500 with 285/55/20.  My truck is stock with the stock front cranked all the way, it does clear barely.  I have a leveling kit going in next week to smooth the ride out.  I’m wondering if I can fit 275/65/20’s if I raise the front a tad more.
Hey sharp looking truck!
Just curious if you added the box corner protectors on? Located in front corners of your box? I been trying to find some for my 2015.
Thanks!
Leave it be, how often are you truly at full lock? Even then it makes zero difference, wheel spacers come with their own headaches.
Finally got the sled deck and the sleds on the truck.  Sure miss my 8' box though...
Fall camping in the Allegheny National Forest
Edited by steelcity
My new edition, traded my 2016 2500 6.0 for a 2016 High Country 3500 6.6, needed to be able to pull a big 5th wheel and the 6.0 wouldn't do it. Both great trucks. ?
If anyone is interested, I have a blackbear autocal and aFe Momentum intake  (less than 3k miles on the intake) I need to part with. Pm me for more info.
Edited by AK_GONZO
My new edition, traded my 2016 2500 6.0 for a 2016 High Country 3500 6.6, needed to be able to pull a big 5th wheel and the 6.0 wouldn't do it. Both great trucks. [emoji106]
Blackbear from your 6.0?
Yes....but, I just sold it all about 45 min ago.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
