L83 Cam Swap
Evanski9
I spoke to comp cams. Here's what I bought for my `14 5.3
Comp cam 624-512-13 hydraulic roller cam
Phase limiter 5456
Spring kit 26925ts -kit
The cam and phase limiter will cost 502.18 thru compcam
The springs run about 436.39
You will need a tune. Hardened rods recommended. Rockers can remain stock. Lifters are recommended to be swapped too. Hope this helps
  • Replies 96
I cammed my truck. Comp cam recommended 624-512-13 cam 5456 phase limiter
And 26925ts -kit for the springs. Cam and limiter are 502.18
  • 2 months later...
I'm waiting for it to show up. I have a couple more mods to do in conjunction. Need to gather all the parts.
Any updates on your LT1 cam?
I bought a SS Camaro instead. Goes fast, more fun to drive than the truck.
If anyone is interested in the cam, PM me or look in the classified section of the forum.
  • 4 months later...
ran into this thread while trying to get info on swapping cams
not much out there, so I jumped in and did it myself. cam, springs and injectors along with a 2.9? whipple, on my son's 2105 Silverado LTZ .
I am in the tuning stages (hp tuners)
Anyone wanting to do this themselves, I used a few tricks, not mentioned anywhere that I've looked.
Started by buying a 1 month subscription to Chilton online. Some good info, but cam swap begins with removing the engine....lol
Props to you. That is some labor intensive work right there. Post up some vids and dyno numbers.
Will do.... anyone wanting to do this themselves, let me know, I might be able to answer some questions or fill in some blanks
You did the LT4 cam right? i'm over on performance trucks site.
RT
yes...lt4 cam, valve springs and injectors...similar to kb
why would you have to remove the engine to swap the camshaft? Is there not enough room after taking the radiator out?
no, don't remove the engine, just the radiator and in my case , move the ac condenser out of the way
invest $16 for 1 month of Chilton online, but ignore the first step 'remove engine' lol
other notes: the oil pan does not have to be lowered, the oil pump stays put. alternator, ac compressor, water pump and front timing cover, including 2 bolts to the oil pan must be removed. The harmonic balancer is a tough one, it took a 700 ft. lbs impact gun to remove the bolt ( tty not reusable and a standard 3 jaw puller with short jaws to remove the balancer (it is keyed)
when timing cover is off, rotate crank until cam timing mark is lined up either straight up or down and place a witness mark on something non moveable. This is needed in that the crank sprocket timing mark is hidden behind the oil pump. cam is held in by 1 bolt, very tight . It is part of what they call the cmp actuator and is not reusable (tty)
rockers and pushrods removed, cam is spun to lift the lifters, 5/16" dowels to insure that they don't drop , timing chain tensioner has to have tension released, remove the phaser/cam sprocket and cam retaining plate and out pops the cam.
without moving the crank, line up cam with the pin at 3 o'clock , phaser/cam gear with the arrow pointing to witness mark and assemble with new actuator bolt (tty)
it's like any other ls cam change with a few twists.
By the way, don't forget to do a C.A.S.E. learn with the PCM after doing a cam swap. It sync's up the camshaft timing to the cam sensor for more accurate spark and fuel injector firing. I did this with every cam swap I did in the 99-07 trucks. :)
