Traded my Silverado today
MikeNH
I only took the one photo today but the Silverado is gone and a 2015 Wrangler Rubicon has taken it's place. Pretty well optioned, I've only driven about 15 miles but I do quite like it.
  • Replies 76
I can't even look at you right now so disappointed. Lol
Congrats.
I am beyond disappointed :nonod::shakehead:
Looks nice. Hope you enjoy it as much as the silverado.
Dude you were actually the first person I told about this last summer at Lingenfelter. And you seemed a lot less hostile about it back then. :lol:
Thanks everyone! It's a big change from the Silverado (I made a u-turn without using reverse!) but I like it so far.
How is the power and the comfort compared to your truck?
It has all of 30 miles on it so I haven't really gotten on it. But it has 4.10 axles and the transmission is geared fairly short so it does well around town. I've had three 4-door models as rentals and they weren't hot rods but they moved well enough and thats several hundred pounds more with 3.21 gears in the base model.
The Jeep is obviously tighter than the Silverado inside (I haven't even bothered to see if someone can fit in back with my seat set where I like it) but because the seat is tall, you still get a good amount of leg room. I will miss the various storage areas the Silverado had, but there are some storage solutions I can buy to help make up for that.
Those are the only Jeeps I would probably consider, not much of an SUV guy and those Wranglers can be fun off-roading. Glad you have a hardtop instead of the vinyl top or whatever material it is. I just see someone easily breaking into those with a decent knife lol.
It's still too small for me though, I'm just used to full size Chevy trucks. Even a full size car seems small to me and I'm not even a tall or big guy.
:lol:
I am not hostile.
Any mod plans?
Ryan
[emoji38]
I am not hostile.
Any mod plans?
Ryan
Like him not being a mod anymore? [emoji23]
That is the last thing I thought you were going to buy! Congrats, looks nice!
Nice. I have a couple co-workers with the 2 doors and 1 with a 4 door. I like the looks of them, but would have a hard time getting a 4 door instead of a truck next time around.
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 251 Guests (See full list)
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
