Do you change your oil yourself?
The good ol oil eyeball test method. Makes me wonder why anyone would pay a company like Blackstone Labs $25 to get a real lab sample done. Why get synthetic oil if you're going to dump it in 5K? What a waste.
  • Replies 95
I change the oil on my truck every 5k miles. I use the factory filter and mobile 1 oil. I would also change it once a year if I didn't drive enough miles a year for the light to come on.
Same as I do. Every 5000 on the oil and rotate the tires every 10000. Easy to keep schedule and one I use on all of our vehicles.
Makes me wonder why anybody would spend 25.00 dollars on a good ol blackstone oil test? Run the crap for 10K miles it's a personal vehicle not a drag car!
I agree, but with so many people who spend the $60 to buy synthetic oil only to change it in 5K because they are so anal their engine is gong to break down because visually the oil is black, spend the $25 to see there's still tons of life in that oil and put to rest your OCD. Modern day oil has come a long way from the 1970's.
How to Change Your Oil...Women:1. Pull up to Jiffy Lube 3000 miles after the last oil change.2. Drink a cup of coffee.3. Fifteen minutes later, write a check and leave with a properly maintained vehicle.
Men:1. Go to O'Reilly auto parts and write a check for 50 dollars for oil, filter, kitty litter, hand cleaner and scented tree.2. Discover that the used oil container is full. Instead of taking it back to O'Reilly to recycle, dump in hole in back yard.3. Open a beer and drink it.4. Jack car up. Spend 30 minutes looking for jack stands.5. Find jack stands under kid's pedal car.6. In frustration, open another beer and drink it.7. Place drain pan under engine.8. Look for 13mm box end wrench.9. Give up and use crescent wrench.10. Unscrew drain plug.11. Drop drain plug in pan of hot oil; get hot oil on hand in the process.12. Clean up.13. Have another beer while oil is draining.14. Look for oil filter wrench.15. Give up; poke oil filter with Phillips head screwdriver and twist it off.16. Beer.17. Buddy shows up. Finish case with him. Finish oil change tomorrow.18. Next day, drag pan full of old oil out from underneath car, dump in hole in back yard.19. Throw kitty litter on oil spilled during steps 11, 15, & 18.20. Beer. No, drank it all yesterday.21. Walk to 7-11 and buy beer.22. Install new oil filter making sure to apply thin coat of clean oil to gasket first.23. Dump first quart of fresh oil into engine.24. Remember drain plug from step 11.25. Hurry to find drain plug in drain pan. Pan is empty. Find drain plug in back yard hole.26. Hurry to replace drain plug as last drop of fresh oil drains onto floor.27. Slip with wrench and bang knuckles on frame.28. Bang head on bumper in reaction.29. Begin cussing fit.30. Throw wrench.31. Cuss for additional 10 minutes because wrench hit Miss December (1982).32. Clean up. Apply Band-Aid to knuckle.33. Beer.34. Beer.35. Dump in additional 4 quarts of oil.36. Beer.37. Lower car from jack stands.38. Accidentally crush one of the jack stands.39. Move car back to apply more kitty litter to fresh oil spilled during step 26.40. Drive car a quart low for 7000 miles when it'll be time for another oil change.
Hahahaha soo accurate!! This was awesome
Waste of what? Are you paying for them to change their oil? I see people throw more money away on going out to eat on a Saturday night than it costs to do an oil change with synthetic. And is there an oil shortage? Not so anyone would notice. And used oil is recycled and re-refined and used again anyway. And synthetics are not all that expensive. There are sales all the time, and some get their oil commercially, so cost is cheaper. And I can get my oil sample kits and testing for $10 each, complete with postage paid. Just ordered another batch of them with my oil order from my commercial supplier. Just because some here don't know how to shop they feel they need to take stabs at those who do things differently.
So I am trying to figure out what is the waste you are referring to.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
