Ok, so lately I've been noticing the 6.2 stumbling a bit, hesitating, lower mileage - even more than expected for winter - etc. and began getting more concerned about intake valve buildup. 26k miles after all. Decided to Seafoam/CRC. Went with the CRC GDI IVC because #1- it appears to be a product developed specifically for this application instead of generalized top engine cleaning such as Seafoam (which I'll say has served me well in the past and may do just fine) and #2- Anything with a name comprised entirely of acronyms must mean business.
Oh. My. God.
The difference was simply amazing. I guess the bad behavior had sneaked up on me, but I had no idea just how bad it had gotten. Worth EVERY penny. Even has a $5 mail in rebate right now. I'm gonna do this every 5k miles.
  • Rough idle - gone
  • Off idle stumble - gone
  • Not-so-smooth acceleration - gone
  • Power - it's back
  • Mileage - early reports from ~100mi would suggest absolutely no less than a 4 mpg jump. No joke. Amazed
I was expecting a big puke of soot, but nothing. Nada. Not seeing that made me think it hadn't worked, well boy o boy was I wrong!
If you have 10k or more on your truck go to Autozone NOW and grab a can. Only takes an hour total and you will thank yourself for it!
Going to definitely consider this on my next oil change....I just cleaned the mass airflow sensor and changed air filter and noticed a smoother throttle response.
Do you run a catch can?
Nope, but guess who just ordered an ADD W1 :thisguy:
Considering that this is pulled INTO your cylinders, I wonder if it washes the oil off the cylinder walls. Also, does it SOFTEN the deposits or merely loosen them. I'm not sure I'd want hard carbon pulled INTO my cylinders.
While I don't really disagree with you, I also don't want carbon deposits building up on my intake valves. But alas, that's exactly where we seem to be finding ourselves these days.
My guess is that it softens them. Loosening is a difficult thing for a chemical to achieve. A solid piece breaking off and going through the cylinder sounds more like mechanical removal. Besides, you're kidding yourself if you don't think little bits will naturally begin to break off and fly through the cylinder. Probably the big ones too.
As for washing of the walls, meh, even if it did it would have a very minor if any effect wearing of the walls long term. The area above the rings shouldn't have virtually any oil anyways.
Subscribed but y didn't u go with bg or something like I heard it was top notch ???no bashing just curious
As in BG cleaning products or catch can? If cleaning product, well the CRC was just a few miles down the road at Autozone (very handy) and it seems to be getting good reviews. I'll certainly throw my hat in that ring as it certainly worked well, results were immediately obvious from the moment I cranked her back up.
The purpose of the post wasn't to tout CRC. I could care less so long as it worked. My point was to share my experience with intake valve cleaning and the benefits therein.
I used this on my work truck and I can say without a doubt it brought the 4.3 back to life it had 90,000 on it at that point. I just redone it at 115,000 and it is still running great. Here is a video of how to do it
Seems odd that you would see such an effect with direct injection.
Well, air is air. And fuel is fuel. To make it all work you have to have the appropriate amounts of both. With fuel, you can actively pump it into the chamber. With air, it's at the mercy of fluid dynamics. If you have any deposits on your valves (read up a bit, you'll find that it's a issue with virtually all DI engines), then you're not getting the air that you should.
I just did my truck with seafoam. I can't tell a huge difference yet, but we will see over time. Used my window scraper to keep the rpm around 2000.
  • Like 4
I may try this the CRC this month as well, I have almost 18k on mine.
While DI is good, the bad is that GM recycles all of the oil mist back into the combustion process. While fuel will evaporate, the oil hits the backside of the valves and then get heat baked onto the valves. Even if some bits came off and fell into the cylinder it wont hurt a thing, it will either get vaporized during the combustion process or else pushed out the exhaust valve. only bad then is if the chunks are large enough they will end up in front of the primary cats which could lead to clogged cats down the road.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
