I only have 8k on my truck, was a demo that had 2k on it when I bought it. I have owned it for a year and have only driven 6k miles (work is only 4mi from my house) so I am going to give this a try this weekend as well. I can definitely tell a difference from when I got it and now in performance. I think a lot of it is attributed to the fact I drive such short distances and the engine doesn't ever fully heat up so there is probably some buildup on my valves already. I will be installing a catch can in the next week or so as well.
Edited by hotrodz37
No gas, of any type, will have any effect on this issue since the gas never sees the back of the valves. Southern described it very well. Non-DI engines can benefit, but not DI.
I'm aware of the function but Is 87 regular dirtyer than e85 I mean the valves do get some fuel from the valves kinda like a backwash
Any canadians doing this? If so what product did you use since this CRC stuff doesn't appear available in Canada.
If you look back I showed how I did it with seafoam.
Got ya! Will give it a shot a little later!
Ok, so on my usual commute this morning I reset the DIC trip A. Now, over the last few weeks I've been watching it close. It's almost all interstate, but there's a LOT of construction going on so every day it's about half cruise @ 70, and half stop and go. I'll admit this morning things went pretty smooth without a ton of stop and go, but the last 2 miles definitely took 10 mins or so. Anyway, I've been clocking in around 17.5 to 18.5 mpg pretty consistently which I at least partially attributed to winter gas. Seems I was wrong!!!
FYI, winter gas has little to do with MPG. Cold temps, not the gas, have much more of an effect on MPG.
Best to hop the border and buy a few cans
Bah, seafoam will do I think.
More than likely. It seems seafoam has been around longer too. I remember people talking about using it on every forum I've been on for vehicles. I've never used a cleaner product in my engine until now though.
I'm still averaging about 1mpg better than I was before the treatment.
CRC products are very good though. Their brake cleaner is an awesome parts cleaner. Been using it for years.
ya their brake cleaner is awesome, I use it to clean everything on my truck that gets oily/greasy. Its readily available in Canada.
I have a feeling seafoam is stronger. Hence the 5 Min vs 1 Hr heatsoak time.
Did you still do 30 second long sprays at a time?
Sorry if you mentioned this somewhere in the 6 pages.
I found it was taking for ever to spray it, I did about 45 sec - 1 min intervals and then I would check to see how much was left in the can.
I did both the seafoam and Crc, but not together. Seafoam 2 months before catch can install and crc day of CC install. It seem to take away the rough idle that was developing and got some throttle back, but my only question is how often can we use it? Will it do damage if you spray it often,Because if it helps, can I spray it every other month? Anyone?
Just a heads up to anyone going to do this after as many miles as I have on my truck (over 70,000km/45,000 miles). I was just doing some errands and I noticed my mileage decreasing big time, went from my average of around 20l/100km to almost 27l/100km and then I noticed my idle started to get pretty rough while in drive and stopped at a stop light. When I went to accelerate my check engine light came on.
I used torque to find the code, having a feeling a head of time what it would be and I was right. P0420 catalyst bank below threshold. Now I am not 100% certain the seafoam caused it, but I don't think I'm being unreasonable by assuming the free'd up carbon is now stuck in my catalytic converters.
I reset the check engine light and my mileage has dropped back down to 23l/100km just in the short trip home. I checked torque again when I got home and the truck hasn't finished runnning its test on that catalyst bank yet so I can't update on this. Luckily if it does come back it should be covered under warranty.
The other possibility is that I have an exhaust leak, hopefully they do not give me any grief about my welded on muffler if I have to take it in for warranty.
Edited by projectsummit
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
