So my father has the EXACT same truck as me. I drove it today and it is totally a different feel. No squeak, and seems to have a lot better acceleration and not as much transmission and throttle lag. Wtf?
I just noticed one difference between my dads truck and mine. I have the 3.08 rear axle and he has the 3.42. Could that make any sort of huge difference?
With all due respect Patsy G, the dealers aren't helpful at all. I've already refunded my extended warranty because they won't fix anything on my truck unless it's on fire and shooting fireworks into the sky. I've paid out of pocket to fix things they wouldn't. Warranty means nothing.
Hey Kev,
We regret hearing you feel this way and apologize for any negative experience at the dealership. Again, feel free to send us the requested information via private message if you'd like for us to follow up on your behalf. We're happy to assist any way we can.
Sincerely,
Eddie A.
GM Customer Care
I also have the exact same noise. The Dealer will replace your cat back however if it starts making the noise again.....too bad. I think I will try a clamp first. Only issue with the clamp is a possible drone when in V4. And I hate drone.
clamping it will get rid of the squeak, but yeah you'll get a slight drone when cruising in V4 mode. I clamped mine all of this past winter, but recently took the clamp off. Of course the squeak is now back and I was trying to spray some lubricant in there but it doesn't seem to help.
this issue just started for me recently. Didn't hear it at all last summer. The afm will probably go out in high mileage anyway, as with the radio screen, and other "programmed" features. Would it changed mpg or pick up? Or affect anything really?
If clamped
My 2014 GMC Sierra All terrain 5.3 Squeaks. At first I thought it was a vacuum hose or something but this makes more sense.
Ill be contacting my dealership when I return home.
My 6.2 dose the same thing and ONLY does is going from v4 to v8 so is it the flaper or something todo with the AFM ??
Its the Flapper.
ok thanks glad to hear that is all it is
Dealership told me "posible solenoid" but did they attempt to fix it? No.
solenoid to what AFM ???
So I purchased this Siverardo back in April of this year. It now has just over 2k miles on it. This truck had the crossover pipe replaced when I purchased it because I found a crack in the pipe where the factory tooling flattens it.
For what it's worth, I have this "Chirp" as you say, but I hear it as a "Ching" sound also. It happens always when I allow it to coast a bit then hit the accellerator. I also hear a lot of rattles coming from that area mostly on cold start-up and then it dissapates a little.
I brought it to the dealer here in Massachusetts. I gave them a typed paper explaining all my concerns. They printed out a couple of reports and told me it was normal noise.. It's very annoying.
They did take care of the 70mph vibration but these driving sounds and noise are bad also... This dealership has seen me alot, but hey, I just took out a mortgage on a truck and I think the issues should be taking care of.
One thing I also tried, because of my prior experience as an auto mechanic, was having someone hold their hand over the tailpipe with a rag.. You can definately hear leaks up there... Anyone else hear this? I was wondering if this could also be linked to the strange noise I hear when traveling down the road in the left lane, say against a road partition... Strange sounds being bounced back...
Mine just started this a couple months ago. Would greasing the flapper or even partially keeping it open help. A louder exhaust would eliminate the noise I assume?
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
