Only if you want the front higher than the back!
Not true. I only have .5" of rake from the front to the rear. If i utilized the rear block I would still have an inch of rake from the front to the rear. I think it all depends on the configuration of the vehicle you have.
I just bought my 2015 about 2 weeks ago, all my trucks have been leveled, the only thing I've ever noticed after install is how much better they look. I leveled mine two days ago and showed my buddies who have 2014-15 seirras and they didn't know it made that much difference. I say go for it!
Edited by mctred
Does your have the Z71 suspension? I have read where that may also make a difference... I followed postings on this forum before I did my truck and it seemed that no 2 trucks are alike... JMHO.
No i just have the standard suspension associated with having a 4x4 and i have factory 20" rims. But i measured it out and in the beginning it was only a three inch difference and now its only 1/2 inch difference.
I'm pretty sure that the springs are the same and that the only difference is shocks, grill, badging and interior differences. I kinda wished I would have stayed with just the 2" level kit but I'm not gonna pull stuff off and have to pay for another alignment just to satisfy a seldom thought of indifference.
My truck does sit level but maybe just a bit too high for the tires I have now. I seldom pull a trailer and if I do it's a single axel, pretty lightweight stuff.
I have even read on here that some guys have seen differences from one side to another concerning the height of their truck. I get looks all the time and a lot of complements too so I'll leave it where it's at.... for now. :crackup:
You have a 2.5"?
You have a 2.5"?
Yes, I have the 2.5" level lift kit from Rough Country. I have an LT Crew cab 4X4 and I do sit level front to rear.
I have not adjusted my headlights since i got my 2 inch last friday. I have not been flashed yet. Is there a chance I can leave them alone?
Have had mine on since February and never been flashed once. The truck sits low enough already, don't worry about it
Installed the 2.5" RC on my 15' crew. Looks great. Handles better i feel too, more stiff. Very happy. Sits level front to rear.
Its true Z71 has a higher rear, I was going to do 2.5 in the front and 1 in the back, however due to the z71 I only had to do the front
How many guys actually adjust their headlights after a 2" level? I'm having my level installed tomorrow and never thought about it to be honest.
Refer to post #69
I have had my RC 2.5" level since January and have had one person flash me and I didn't do anything to my headlights. I say don't bother trying to adjust them with a 2" level.
i have a z71 and called rough country yesterday...and was told the same thing...no point in 2.5 unless i really wanted the extra .5 inch...the 2' would level me perfect and with no disadvantages from the 2.5", can run same larger tires as desired.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 900 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
