fpdsniper Posted July 1, 2015 Posted July 1, 2015 Top is leveled with RC 2.5"with toyo MTs, bottom is stock. If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance Sent from my SM-G900V using Tapatalk Looks great! At first I thought it was too high in the front, but that appears to be a camera angle thing. Is there any lift in the rear with this kit? Where did you purchase?
irish4life8911 Posted July 1, 2015 Posted July 1, 2015 Looks great! At first I thought it was too high in the front, but that appears to be a camera angle thing. Is there any lift in the rear with this kit? Where did you purchase? Ordered directly from roughcountry.com It's the 2.5" kit, which is 2" block under the shock and a 1/2" spacer on top. Then it comes with a 2" block for rear to replace the 1" blocks. It still has some rake, but not as bad as stock
z71 chevy Posted July 1, 2015 Posted July 1, 2015 Ordered directly from roughcountry.com It's the 2.5" kit, which is 2" block under the shock and a 1/2" spacer on top. Then it comes with a 2" block for rear to replace the 1" blocks. It still has some rake, but not as bad as stock Looks great what size toyo are those?
fpdsniper Posted July 1, 2015 Posted July 1, 2015 Ordered directly from roughcountry.com It's the 2.5" kit, which is 2" block under the shock and a 1/2" spacer on top. Then it comes with a 2" block for rear to replace the 1" blocks. It still has some rake, but not as bad as stock Perfect. Exactly what I'm looking for. I plan on using the stock 18" wheels with some Goodyear Duratrac's when I can afford them. I want to avoid any "issues" at all costs. I've run Duratrac's on my last truck for a few years, and they are awesome tires. 1
irish4life8911 Posted July 1, 2015 Posted July 1, 2015 Looks great what size toyo are those? 275/65/20's. = 34" tires 1
fpdsniper Posted July 1, 2015 Posted July 1, 2015 Is a transfer case drop kit not needed with this? Is a transfer case drop kit not needed with this?
LongrangeLauber Posted July 1, 2015 Posted July 1, 2015 Is a transfer case drop kit not needed with this? Is a transfer case drop kit not needed with this? Never heard of a tcase drop kit. If you're referring to a front diff drop kit, you don't need to worry about it on a level kit, that's only for true lift kits and at that point it is built in with the drop crossmembers and such
fpdsniper Posted July 1, 2015 Posted July 1, 2015 Ok, next "newby" question. (New to GMC, that is) I see that a lot of you are leaving that front air dam in place. Just personal preference?
LongrangeLauber Posted July 1, 2015 Posted July 1, 2015 Took mine off. Makes it look taller, gas mileage didn't change either
SILVER SLED Posted July 1, 2015 Posted July 1, 2015 I started with the 2" RCfront lift to get the lowered front look gone. 2" seemed a little high once installed for a while, so I went with the rear spacers from the 2 1/2" RC level kit (you can buy them seperately). I like the way it looks now, has a little bit of rake to it.
quise2024 Posted July 1, 2015 Posted July 1, 2015 So with a 2-2.5" level kit, how big of a tire can you get before you start to rub at a full turn?
Prdtrgttr Posted July 1, 2015 Posted July 1, 2015 Justinass, that is a sick ride!!! I love the look of that truck. Thanks for posting pics!!! Creamy butter, don't even think twice. Go get the lift done ASAP I'd go with the taller 2.5 ish inches up front and add an inch block to the back. My brother in law, did the truxxx lift leveler to his GMC AT and it's one sick ride. On my 14 Silverado, I did the truxxx lift. On my 15 Silverado I used a Ready lift kit, which added 2.25 " up front and 1.25" in the back. Lift/leveling kits really improve the look of these trucks. Plus the added clearance is appreciated when driving off road! Justinass, that is a sick ride!!! I love the look of that truck. Thanks for posting pics!!! Creamy butter, don't even think twice. Go get the lift done ASAP I'd go with the taller 2.5 ish inches up front and add an inch block to the back. My brother in law, did the truxxx lift leveler to his GMC AT and it's one sick ride. On my 14 Silverado, I did the truxxx lift. On my 15 Silverado I used a Ready lift kit, which added 2.25 " up front and 1.25" in the back. Lift/leveling kits really improve the look of these trucks. Plus the added clearance is appreciated when driving off road!
VinnyZ17 Posted July 2, 2015 Posted July 2, 2015 Stock 4x4s shouldn't look like street trucks. I put a MotoFab 1.5" level off ebay on mine. Went up to 265/70/18 32.6x10.7 Hankook Dynapro ATM tire and now it looks like the 4x4 sticker belongs on it. I also took the front air dam off and I've lost less than 1mpg. It still has a little rake so when I pull a small trailer with hunting gear it isn't nose high. I'm currently looking into getting another set of wheels and tires. Possibly 33x11.5 or 33.5x12 on 17's with an offset between 0 and +12. Everything I've researched says both wil fit just fine.
Chadwilliam1 Posted July 2, 2015 Posted July 2, 2015 rc 2.5 toyo 33x12.5x20 love it nice truck. I had Toyos A/t Open countrys on my last truck and they were the best tires I have ever owned. They did great all year long. I loved them.
Register a new accountSign in
