Here's my 2015 double cab ltz with a RC 2.5" leveling kit with rear blocks. Makes a ton of difference in the looks department I think. My 275/60R20 duratracs with fuel maverick 20x9 +01 offset are on the way! 45075bf321f98995ea59a2e562b32cec.jpg
Edited by 15ltzandy
Love this information. Z71 with 2" RC Level. Was wondering if I needed to adjust headlights, and this thread answered it for me. Thanks!
Sent from Tapatalk App - Samsung S6
I finally got my Ranchos where I want them. 3 in front and 5 in the rear. I had put the front at 0 and it was like OEM ranchos. I jumped up to 3 and it rides great.
Its true Z71 has a higher rear, I was going to do 2.5 in the front and 1 in the back, however due to the z71 I only had to do the front
Where did you come up with that information?
The 4x4 pickups with the Z71 suspension sit at the same height as any other GM 4x4 truck that I have ever seen. The suspension differences between Z71, Z85, Z83, NHT ect. are mainly the stiffness of the OEM shocks. Shock length are all the same, but the shocks don't adjust ride height anyway.
All of the pickups also come with the same size rear block on top of the rear axel. The leaf springs are also the same measurements from center pin to eye with the same arch no matter the suspension package.
If any of the trucks actually were going to sit higher in the rear, common sense says it would be the options like the NHT/max tow that are rated for extra weight. Even if there would be more leafs in the pack to make it stiffer and give a higher spring rate to handle a heavier load, the truck still isn't lifted with the identical spring measurements.
The arch and measurements from center pin to eye are the same on the OEM leaf packs.
I am going to have to get some measurements next time a 14-15 Silverado/Sierra comes into the shop. The new trucks may be a little different but I doubt it. It would be very noticeable if one were higher than the other. Only difference I have seen are between 1500 & 2500.
Sent from my crappy iPhone 6
using Tapatalk
  • 4 months later...
Top is leveled with RC 2.5"with toyo MTs, bottom is stock.
If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance
Sent from my SM-G900V using Tapatalk
That's probably what I'm about to do. Don't you have to swap rear blocks to get this leveled. I'll be working with a 2015 All Terrain and wanted about a 1/2"-3/4" rake?
Thanks
Ok I am really thinking about doing this and running 275/65/20 with the stock 2014 Denali rims. I know the tires are a 34 inch and a load range E which I was wanting to stay with a P metric tire just due to the weight and ride!
What are we getting with Gas mileage with the 275/65/20 E rated tires and a 2.5 lift kit or even the 3 inch Motofab kit ? I am going to stay with an AT tire and haven't decided which one yet either!
Either
Toyo Open Country AT2
Nitto Terra Grapler
BFG AT2
Yokohama ATS
Rancho Quick Lift if your budget allows......
What about Beilstein 5100. is that better them Rancho quick lift. or not.
I have a 3.5" level and I'm running a 35x12.5x20 destination m/t on a stock yukon rim
Sent from my SM-N910V using Tapatalk
Who makes a 3.5" leveling kit? Are your angles alright?
  • 7 months later...
You have probably answered this a thousand times so forgive me, but did you install the entire kit front a read? This is how I want my rig to look!!! Thanks!
rc 2.5 toyo 33x12.5x20 love it
Looks awesome!! Did you install the entire kit front and rear?
those pics are with just the front installed...i did install the 1" taller blocks on the rear a few days later...
it looked a little nose high in person...plus i tow a camper pretty often...
Before / Stock
RC 2.5 Just the front with 275/60/20 ko2 6964ef42fe843c2e99d207b18bd60f2b.jpg
The hole kit front and rear
We have the same truck. I really like the looks of yours now. What tires do you have and are you happy with them? Do you have a photo showing your truck from the front with the air deflector removed?
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 859 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
