If you had 31" tires before, your speedometer will be off 6.4% and so will your MPG so.... 20.4mpg on a 19.2 display.
Impressive at 19.2 on a 33... 20+ is damn near amazing. I wish I could drive like an adult.
Remember that was highway miles mostly... With the cruise set and me and my Sirius/XM just riding & guiding.
Top is leveled with RC 2.5"with toyo MTs, bottom is stock.
If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance
Sent from my SM-G900V using Tapatalk
As far as I'm concerned, the top pic is what an AT should look like from the factory.
  • Like 3
Agreed, but I think you should take that front air dam off. It does just about nothing but reduce your ground clearance. I took mine off and have seen zero change in mpg, assuming that's what it's on there for. The front looks way better with it removed, IMHO.
That would be perfect if you are not going to use the truck for towing or hauling. The rear end is going to sag as designed when the truck is loaded or a trailer attached. Being just about perfectly level, when the truck takes that weight the front end is going to point to the sky.
Very nice looking truck just not an ideal setup for towing/hauling.
Sent from my crappy iPhone 6
using Tapatalk
using Tapatalk
I agree with this in part. I think the trucks that are leveled look great. I think GM is probably the most nose-low from the factory of any of the big 3. However, when I hooked up my 6,000 travel trailer to my Silverado, even with properly tensioned weight distribution bars hooked up, the back came down a little and the truck sits failry level when hooked up and gear the back of the truck for a camping trip.
If I had a leveling kit on my truck I have to believe the nose would be at least a little high, which is not ideal as it takes weight off the front axle which can adversely affect handling. Might be an issue, might not.
I still may do a small leveling kit someday in the future I did one on a 1989 K1500 Silverado I had years ago and loved what that did for the looks of the truck, just as you guys' leveled trucks look great. But if your towing or hauling heavy loads, just give it some thought first.
Just my .02 FWIW
Here it is.
I need to get better pictures.
No pics were uploaded :-(
Do i used the RC 2.5 level in the front and left the factory rear blocks on the truck.
Only if you want the front higher than the back!
Did you guys end up needing an alignment? I am thinking bigger tires so I might wait until I buy them.
You should have a front end alignment done whenever making changes to the front suspension.
using Tapatalk
I know its the right thing to do but if I decide to wait a month and get bigger tires will it really hurt?
nah, just wear out your tires quicker, if you wait a month, the odds are you'll probably get it done a couple months later...so i would do it now than later.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
