Dinged Frame = Totalled Truck?
  • Replies 46
Well that is a lot more than a dinged frame in my opinion. I would call a dinged frame something like the one dent at the rear cross member.
With that said, I would buy the salvage. I need a good work truck that I can beat on.
The bumper step is melted. It's useless as a work truck now. :rolleyes:
Rear cross member:
You sure are hard on trucks!
I agree on wanting magnee ride control, it is nice!
You need to step up to a Danali HD to get the ground clearance and bwedy frame.
You obviously do some serious off roading to cause frame damage like that. I'm not familiar with the tx law that states it has to be declared a total if the frame is replaced and I'm licensed to adjust claims in tx. Not saying it isn't possible but I'd want to see a copy of the law if it were me. Seems ashame to total a truck worth 40k+ for 17k in damage just because it needs a frame. Good luck in your decision
My work trucks look like that in just a few months and we drive them to about 150k miles (3 to 4 years). The frame is banged up but I would not think it needs replaced!
The pictures show serious damage to the truck. Write it off as totaled and move on. Your insurance rates may go up but if you want to play your going to pay.I would suggest buying a motor cycle if you want to catch air off road.
Another concern if you allow it to be totaled, what is pay off, what will insurance cover and what do your finances look like? Just a thought, hate to end up letting them total truck and you still owing on it. Depreciation is hard and fast once you sign the dotted line at the dealership and some insurance companies won't cover amount owed if higher than value.
I'm still waiting on the details from my insurance. They're supposed to get back with me today or tomorrow with an offer and options.
I only owe like $23,500, and I hope it will appraise around $45k.
Regardless of what they appraise at, go looking for "your truck" out there on dealer lots right now. See what they're actually selling for. Use that information to have an informed discussion with the adjuster as to what it should ACTUALLY be valued at since you'll need to replace it.
I've checked the value at all the Blue Book/NADA sites, as well as checked prices on Autotrader. They're going for between $44 and $47 in my config.
I guess I will play devil's advocate here...
Who spends 50K on a truck to run it off road like you did? I love my truck and use it as a truck, but I'm not running my daily driver up the trail. I'll buy a $500 beater for that.
Again...no disrespect intended...I'm just surprised you took a DENALI off-road...
I went on several trails while I was in Colorado without any problems. There was just one that ended up being much more difficult than I expected. If I would have remembered to remove my running boards before my trip, I probably wouldn't be in this situation as there would have been very little visible damage - just the front bumper. Oh well. I bought my truck to serve multiple purposes, and it's doing that.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
