Looking for truck bed tool box ideas - Post Pics
I don't have any pictures handy but I bought a DiamondBack HD cover in black with their 13" deep "cross bin" accessory. The cross bin is similar in dimensions to what you'd have in a standard tool box. There's roughly a 5" gap under it, between the cross bin and the bed, so you could still carry full sheets of plywood, etc. without any modifications. The cover is installed using clamps, so you can take it off in maybe 10-15 minutes if needed.
http://www.diamondbackcovers.com/hd/
http://www.diamondbackcovers.com/accessories/#crossbin
  • Replies 60
under cover swing case. lids lock and they lock to the truck. also fit under a cover...as the name suggests lol. not giving up a lot of bed space was a factor for me. i also like the ability to access the boxes from the rear of the truck.
I have been considering a bed cover with a tool box for my truck. The DiamondBack looks like it could stand up to the needs of my husband. My hubby is a version of Tim the Toolman. His philosophy is bigger, faster, more power and of course more weight.
His truck is a 66 C-20, and mine is the 20015 Z71. He is not allowed to haul gravel, rocks, dirt or anything else that is going to ding up my truck. He can use his 66 for that kind of work. But I would like to be able to haul tools, gear and equipment with mine and still have it secure.
  • 4 months later...
Finally got a box installed. I went with the Husky Lo-Pro toolbox from Home Depot. Exactly what I was looking for.
523F03DC-3B12-4CE8-B159-2A9E2D020232_8.j
BCCB4813-C27E-448F-A111-0E94DAFE58F6_3.j
4BB2FAFE-408E-4D7F-92DD-8960C9BAEE86_3.j
The Husky os Junk trust me went threw 3 in a year to i got a cover. .. the low profile Tractor Supply is deeper and I know two people that have had no problems gor almost a year
How much did you give for the TonneauMate? I'm seeing ~$400. I can get 2 swing cases for that and still have $$.
I apologize for the late answer to this question - Here you go:
For my '14 GMC Sierra - 8 Ft. Long bed -
New Truxedo Deuce2 Tonneau Cover (Installed): $450.00
New Truxedo TonneauMate ToolBox (Installed): $370.00
Plus sales tax.
Toolbox is 55" long, 22" wide and 15" tall and sits off the bed floor maybe 6-7 inches.
http://www.truxedo.com/deuce/land.php
http://www.truxedo.com/tonneau_mate/
What issues were you having with them?
I have a low profile Camlocker and couldn't be happier with it. Once you experience the latches / handles you will not want any other brand.
Those do look nice. Not really wanting to spend a close $600 on a toolbox though. Does yours have the rails on top?
Nice box - I picked up the higher profile Husky for mine on CL...$60 & a new lock/key set for $5.
Now you need to get some tools to fill it! Looks clean!
Thank you sir. Very pleased with it so far. Also got the husky toolbox liner at home depot to keep things from rattling on the bottom of the box. You can see it in there.
Since I have taken that picture, I put my tow strap, jumper cables, bunch of tow straps, tool box, and floor jack. Love having all of that stuff out of my back seat!
No rails on mine. I think I paid around $450 a few years ago.
They are expensive but they are really nice. You can easily open and close the latches with 2 fingers
Yea that looks good. The rails on the other ones killed it for me.
http://www.swingcase.us/
heck yes. I bought one of these and I love it! I questioned how large it was to fit all my junk, but I can easily fit my tow strap, bungees/ ratchet straps, gloves & trailer hitch inside with room to spare. I keep a small tool box inside under the back seat for hand tools, but I could fit all that stuff in the swing case if I wanted to.
Plus if you want it out of the way to use the full bed, it lifts off the bracket in 2 seconds.
You can get stuff out without removing low profile tonneau cover, just drop the tail gate and release the lever.
I highly recommend this tool box for anyone who does not need the big one all the way across the front of the bed. You can put one on each side for double the space.
I have standard crossover box. Plan is to maybe add a tonneau cover behind it.
May I suggest you hit craigslist. I paid $60 for this.
TRUCK
    RyGuy43
    RyGuy43
  • Who's Online   6 Members, 1 Anonymous, 623 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
