4wd updates to ecm
BlueSS2003
Maybe everyone who thinks this update made the truck shift better hasn't disconnected their battery in a long time. Doing so resets the learning ability of the tranny and makes it shift better in my opinion. My dealership said it was free even though I'm out of warranty and called it a recall. I do still have power train warranty through.
  • Replies 64
My truck never shifted correctly from day one (about 8 miles on the odometer), and in 19,000 miles it never improved. The update completely changed my truck for the better. I'm very in tune with my vehicles. I'm not sure why you didn't notice a change, but I can assure you that for me this recall was much more than resetting the re-learn procedure.
I haven't had the recall done yet. I was just referring to the other people that say the recall did nothing to their shifting. Which would make sense because the tcm doesn't get touched with the 15304 recall. I'll update when I have mine done on the 21st. I strongly believe the 1st-2nd and 2nd-1st clunk/clank that lots of people experince is a hardware issue and not a software issue. Mine makes a clank noise with a diabloaport tune as well as stock which makes me think its the clutch pack.
I would guess that you're right, depending on the severity of the clunk. My truck would clunk quite often when downshifting from 6th to 5th, or from 5th to 4th. The downshifts were horrible, and felt like the brakes were applied, and then I'd get the clunk / downshift. That clunk is gone now, which I actually didn't expect. If you have a loud clunk when putting the truck into gear, then I'm guessing the recall won't change anything.
For the record, my truck also acted funny with the i1000. It was slightly better than stock, but it still had plenty of issues. I've tried re-installing (even with stock TCM tuning) and it made the truck worse than the stock tune after the recall. Plus, even without throttle boost, I still had the quick 2nd to 3rd shifting that others have complained about with the Diablo product. My truck is now awesome with the stock tune after the recall, and with AFM turned off with the tuner. I'm not happy with the performance of the Diablo canned tune (also had pinging), so I guess I purchased a $300+ AFM disabler.
Mine was updated at the same time the transmission was replaced. Upshifting is much better now except for the first shift from 2-3 where it slips. Mentioned this at the dealer and they said something about the transmission purging air on the first 2-3 shift. The other thing that I notice now is that when downshifting, it does do a better job finding the right gear, but it also slips a lot. The RPM overshoot about 500 then it slips into gear while accelerating.
Hard to know if this was fixed by the update or the new transmission. At least it isn't trying to kill me anymore. Last transmission would randomly not react to gas pedal movement and try to push me through intersections while braking.
This update has nothing to do with shifting at all, I asked the GM engineer about it yesterday and the update only reprograms the transfer case module and nothing else.
Read through the thread. There was a post describing how the tccm was handing the torque management software, and how this recall improves driveability due to the updates.
torque management for the transmission is handled by the transmission control module. I can't find the post you're talking about but I'm pretty sure I remember it being a speculation not fact.
I had the recall done on my truck earlier this week. I don't feel any difference in drive quality. Beside the paperwork saying so, I wouldn't know they reprogrammed anything.
Did mine, service managers, and service writers. All drive exactly the same.
Not me, completely fixed my complaints with slow speed shift habits and indecisive gear selecting. Not in my head as I have been driving the truck for a year now and can most definitely feel a major improvement especially at low parking lot type speeds.
I still think there were different tunes installed by GM at the factory. This would explain why some owners had horrible shifting that was corrected by the recall, and why some owners said their trucks shifted great right out of the box. I often wondered how those guys could ever call the horrible shifting normal. I'm guessing they were the lucky ones from the beginning, and already had an updated tune of some sort.
Read thru what I said, I spoke to the head "read" Chief Engineer over the entire GM truck/SUV line about this update, it only reprograms the transfer case module and nothing else, that module is completely separate from the TCM (transmission control module) which handles shifting and the transmission side of torque management.
The calibration are only different based on the engine in the truck, the engine used has different engine tuning and transmission tuning. That is the only difference, otherwise the tunes are the same. You could pull a tune from a 5.3l engine and 6spd auto from the same year and as long as the gears are the same the tune will be the same for both vehicles.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
