GM gives you everything you need to install dual batteries in your 1500....except the battery and cables!
So I decided I might as well finish what GM started.
Pretty easy. Just add a second battery and route 4 Gauge battery cables along the firewall over to the original battery. Make sure you add a ground from your new battery to the chassis, just for good measure
Now I can run my hair dryer and microwave
IMG_20151026_094232724_HDR_zpsdhbrqbju.j
Hmm...so I could run a sawzall off the 120 plug with this? I tried the other day and got no power...
Don't wanna be "that guy", but a second battery doesn't increase the pitiful capacity of the factory inverter which drives the plug. At only 150 watts you are limited to charging your iPad, or possibly using a high powered toothbrush.
Also without a battery isolator, a lot of the benefits of a dual battery system are lost.
  • Like 6
Not sure what inverter you guys are referring to, I don't have it though. Can't run 110 off my truck. The hair dryer/microwave comment was a joke ha-ha.
I knew you were joking, but people get ideas :)
I saw that and thought it was pretty cool, that there was a spot ready for the second. battery. Are there any configurations that come with 2 batteries from the factory?
No, the 2nd battery tray is unused on the 1500. There are dual battery options but are only available for the 2500 and up. It is a mystery why GM includes the tray on the 1500.
All duramax's have 2 batteries.
Excuse my ignorance, but what would be the purpose of having a 2nd battery?
Proving to my neighbor that my GM is better than his Ford.
What do you have wired with those wire nuts? Why are they are your truck?
Those are all part of the strobes. I think those particular ones go to the front grill LEDs
Can run things longer without the engine running. Also have more starting capacity/power.
I want to get a second battery with an isolator for camping to run lights, chargers etc.
Tahoe police package has 2 batteries i believe as well
That may be why GM provides the space for the 2nd Batt on the 1500s even though there is no Batt upgrade available from GM....gives the police/fire/EMS upfitters a place to put their 2nd battery
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,386 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
