What was the actual alcohol content of the E85?
Sent from my LGLS990 using Tapatalk
Reported on HPtuners was 62% on the 5.3 and 70% on the 6.2. True E-85 reads about 72-73% on the GM sensor and scanner.
Right right, I love tunes and would never drive a stock truck, I just referring to the fact that everyone keeps saying a E85 tuned 5.3 is faster then a stock 6.2.
Both are great motors, really the same motors, both should be tuned regardless.
I hear you, loud and clear and agree.
I can tell you that putting over sized LT rated All Terrain tires makes my truck a rocket ship.
Rookie question: How much of a timing/tuning factor does the 8-10% difference play?
Reported on HPtuners was 62% on the 5.3 and 69% on the 6.2. True E-85 reads about 70-73% on the GM sensor and scanner.
Cool... Will the tune automatically compensate for concentration?
Yes, this is a full flex fuel conversion. It auto adjusts accordingly. All you have to do is drive and refuel. DI engines with high compression ratios (11.5:1 for the 6.2 and 11.0 for the 5.3) love the extra octane tolerance. Peak to peak gains are good but power under the curve is where it counts!
I see your point here, but there are also some who don't have other toys (Basing this off your Sig comment :)). So, this is their toy....so you have to understand it from that point of view.
As an Auto Enthusiast, I like to modify just about every vehicle I get. I know this isn't a hot rod, but I still want my truck to be be as good as possible, both performance and looking. Also, everyone has their own taste and options.
I'll end with what my Son told me the other day, "Don't yuk someone's yum".
My comment wasn't directed towards you and I wasn't quoting you, but now I am. I was quoting the person above about the "internet racers". I like what you had done with the E85 upgrade, it is something I will do as well and even asked Carl about a price for the parts. I'm not doing it to go around bragging or to try to race people on my key board like often happens on these forums. <<<< Not saying you have so don't go and take that out of context too. I would do it to simply have the availability to use E85 as my 15 can't as of now.
So in the end I didn't "yuk" anything... So enjoy that "yum" you have there.
Carl it looks like the wonders of Josh and Zane got you on the pay-for-play. Congrats on being a vendor.
Back at you, i wasn't aiming any yuk at you. I understand exactly what you're saying.
I was just trying to say that some people (internet racers or whatnot), this is the toy for them and if a 15 second brick makes them feel good, let them have it.
SMH... I digress.
SMH... I digress.
Had to look up SMH :)
Shaking my head.... I get all that crap from my sister in-law (much younger). I often feel like an NSA agent decoding her messages.
Edited by sprayed99
Here you go, this is a 15 GMC 6.2 L86 A6 w/air intake. I was hoping for a stoker but it was as close as I could get.
Stock- 332/383
Tuned - 353/409 picked up 21whp and 26 ft/lbs over stock
Tune E85 - 370/432 Picked up 38whp and 49 ft/lbs over stock
15%206.2%20wintake%20stock%20tuned%20E85
Good lawd!! :driving::driving:
I just think its funny people drive trucks that weigh 5000+lbs and they want to get into a dick measuring contest about who has the faster 15 second truck.
I've seen 3 different people post their *stock* CC 4wd 6.2L running 13.6 - 13.7. That .2 -.3 faster than my RCSB 5.3L E85, LT & tuned.
These GenV trucks get it on.
Edited by bigsapper
I've seen 3 different people post their CC 4wd 6.2L running 13.6 - 13.7. That .2 -.3 faster than my RCSB 5.3L E85, LT & tuned.
It's fun to go down the track in anything with balls. I'm itchin to bring mine... but the governor has been holding me back. I will have to tune it to increase the cutoff in order for me to even make a full pass. 92mph cutoff sucks! Probably some tires as well as there's now way it will hook with just 2wd. Trucks have come a long way though! SBC's have come a long way!!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
