Message added by Zane,
Hey everyone, we noticed this question comes up a lot, so we finally put together one master cheat sheet. It covers the exact oil capacity, filter numbers, and drain plug torques for every GM truck and SUV from 2016 through 2026. Bookmark the full guide here so you never have to guess again: https://www.gm-trucks.com/gm-engine-oil-capacity-guide/
Anyone know how much oil actually goes into a 2015 5.3? My user manual says 8.5 quarts oil and filter. The dealership is telling me 8 quarts, but 1 tech there was putting in 8.5 quarts. When he put 8.5 quarts into my truck it reads 0.5-1 quarts high. What is the chance that there is something in my engine that is not supposed to be there?
5.3 and 6.2 recommendation was reduced to 8 quarts from the original 8.5.
Capacity and Viscosity Charts for 2013, 2014, and 2015 engines:
http://sandyblogs.com/techlink/wp-content/uploads/2015/02/TechLink-engine-oil-capacities-2012-2015.pdf
Info from Oct 2014: (says there is no need to drain the extra 1/2 qt, but that 8 qt is the revised recommendation for 5.3/6.2
http://sandyblogs.com/techlink/?p=3822)
Note that the DIMPLES are the full and low marks, not the edge of the cross hatching.
Thanks for the quick replies. Not sure why my 2015 user manual has not been updated since this is from October 2014. Even the online 2015 manual states 8.5 still.
Yes I was using the dimple. It is well above the full dimple and the entire cross hatch pattern.
They were building 2015's before Oct 14, but I'm also surprised the online version has not been updated.
  • 3 years later...
where can I find the 2015 online version of oil capacity for a 5.3 please? my dealer put in 9 and claims 'some take 8 and some take 9'.   makes NO sense
You can look up any vehicle on AMSOIL's look up guide.  They stay current on manufactures capacities.
ok, so 8.  thanks for that link.
Just weird man, I couldn't understand why the service tech said 'ya.. my 5.3 Silverado takes 9 quarts and some take 8'.
  • 8 months later...
So i know 8 qts is what is told for a 5.3 v8 silverado 2018. But when i first did mine. i put in based on dipstick alone, which came out to be around 6.75 qts. But next time the dealer did it. They did the 8qts. I check it and the oil is crazy high. i couldnt even give you an accurate height. any ideas why mine seems way off? either way too high on the recommended amount. and way low if you go by the dipstick.
Dealer could have easily overfilled, since they may be using oil in bulk containers and pumping it in. The "tech" may have just messed up. Change it your self and put 8 qts in and look at the stick. Your 6.75 was incorrect
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
