has anyone added the oem skid plates to a regular 2015 LT 4x4? these would be the same ones a z71 has... i found all the parts online... looks like for less than $150 you can have the same feature as a z71.
thoughts, anyone done this? am i missing anything?
(see attached picture)
Edited by jwester34
My High Country 4x4 came with the front skid plate, if you can call it that. It is just a plastic shield from the radiator support to the front cross member. I think the brackets listed in your parts list are the reinforcing that is under the plastic shield. You can't see the brackets with the plate installed. I think you have all the parts for the front plate. I can crawl under the truck tonight and try to see if there are any other parts.
The other skid plate on the Z71 is the aluminum one that goes under the transfer case. I bought the transfer case skid plate off of Ebay for around $30. The transfer case plate needs mounted with 4 self tapping bolts, I think the same bots as the last item on your parts list. I was in a hurry and couldn't find them online at a good price so I purchased them from the dealer. The 4 bolts cost more than the skid plate.
thanks for replies so far... found some other threads in my search... but nothing with a complete list like mine.
I guess something is better than nothing... but looking at after market metal plates too.
Just fab you up some out of thicker sheet metal and have them bolt up to factory holes. When I had and Xterra thats what all us guys did but we put skids under the whole rig so the hard part was making bends that didn't interfere with flex
I don't think these exist in the research I've done. You'd have to get them custom fabricated.
I agree though for a lot less money, you can add the benefits of the Z71 package for much less than the cost of the package. In my opinion, the only reason to pay up for the Z71 package at all is to get the less chrome-y grill and the carbon fiber looking gauge cluster. But the Rancho shocks are garbage, the "skid plates" are laughable, and you can't get stock size BF Goodrich KO tires for the 18" rims in load range D. I wish I had the 17" rims from my old truck, and I'm eventually adding Bilstien shocks and replacing this Rancho junk.
Edited by Silverado-Hareek
so are you saying they are not worth the $170 or so dollars to add to a non z71 silverado?
agree with you on your other points... Bilstiens and good tires will be going on when these wear out.
Edited by jwester34
that front plastic part is on my non Z71 LTZ, just flimsy plastic. make sure its not already on your truck
Edited by jrob56
My 06 z71 had pretty good skid plates. At least they were not plastic. I got a 2015 GMC Sierra z71 now. Was going to get just a 4x4 but this had more options and bridge stone dueler A/T's on it. And I did not the good years. I was thinking of doing the same thing if I got a 4x4.
No I'm saying the $3,000 price tag to get the Z71 package isn't really worth it from an off-road standpoint. But since there are no real aftermarket plates of any kind for these trucks, yes I would definitely pay the $170 to have some kind of protection.
All Z71 and non Z71 4x4 trucks have that shield and braces that you are looking at. That is the engine shield. Heck even the 2wd have that. The only optional skid plate is the transfer case. Z71 gets the t-case skid standard, 4x4 its optional.
There is a full metal skid replacement set you can get which is a 3 piece kit. You get the plastic engine front piece, a metal oil pan piece and the transfer case piece and bolts. 23176881 is the kit for V8 trucks, retails for $250. The full metal kit is an accessory only either after the fact or when the truck is ordered as a dealer installed accessory.
Is this the kit you are talking about?
http://www.ebay.com/itm/GM-23176881-Underbody-Skid-Shield-2015-Tahoe-Silverado-Sierra-Genuine-OEM-GM-/231389136771
That actually has some metal protection for the oil pan! Wonder if you are able to just get the oil pan plate since the Z71 has the other two?
Tyler
Edited by amxguy1970
Z71 also includes the new 'Hill Descent Control" feature (the one that works sort of like cruise, but will only works when between 2 and 14 mph) as well as the trim changes on silverado (no trim differences on sierra except the label on front fender), different shocks and the description also says a different air filter.
Tyler
I'd be interested in this as well if someone can confirm this will fit a 2015 non-z71.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
