Grill with less crome was worth the Z71 package price to me lol
I would go take a pic and knock on mine to see what they really are but... Its 14 degrees outside lol
Sent from my Note 4 on Tapashit
Indeed. I ordered Z71 purely for the "less chrome" look (although I then added some by going LTZ). Couldn't care less about skid plates.
  • 5 years later...
Can anyone confirm the actual bolt size for the two under-engine skid plates as well as the transfer case skid?  I'm seeing conflicting reports.  Either M10x1.50 with a 25mm length OR M8x1.25 with a 30mm length.  Which one is it?
This is the part number (bolts) I used when I put the metal skid plates on my truck.
Lower Shield Bolt
11518341
Lower Shield Bolt
11518341
Yes I know that's a dealership part where they charge you nearly $10 each per bolt, I don't enjoy getting raped unnecessarily 😄
  • Haha 1
About this 11518341 Bolt
This part is a bolt, hexagon, m10x1.5x25, 14 thread, 28 outside diameter, 6202m, 7114m, tappet, tr-point (transfer case shield), for Hummer, Chevrolet, Chevrolet Trucks, Oldsmobile Trucks, Cadillac Trucks, Cadillac, and GMC Trucks cars. It fits for 649 General Motors vehicles which were sold in the U.S. from 1995 to 2014. It's a genuine General Motors part with an OEM part number 11518341.
This bolt has dimensions 1.40 in × 1.80 in × 1.40 in, it has a weight of 2.24 ounces, usually, it comes in a set of 1 item in retail packaging.
That's the information I thought was correct, but I'm being told it's a different bolt by another guy.  I haven't installed my plate yet and the bolts and tap I bought today are for 10mmx1.50 thread as you said.  So, if what you are telling me is correct, what I bought is correct.
Edited by BlaineBug
Not sure if this a dumb question (most are), but have you taken one of the factory ones out and compared?
I bought extras because the "metal" skid plates take 8 bolts, and the factory plastic shields take 6 (if I remember correctly).
I just ordered the skid plates yesterday.  I haven't taken any bolts out yet.  You are correct from what I hear the front metal plates, which there are 2 of, use 4 bolts each, and the transfer case skid uses 4 bolts.  So as of right now I have more than enough bolts to complete the job.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
