Bed LED wiring question
Espo720
Ordered an oem perimeter bed lamp kit and it has a 6 prong plug. Going into the fuse block on the drivers side there is an 8 prong plug.
Has anyone plugged this kit in before? There were no instructions in the box so I'm hoping theres another fuse block and I can't find it... Already at war with the ebay seller for selling me the wrong harness.
To my knowledge oem bed light kits plug into a socket behind the rear bumper
There is a harness block thats pre-wired, with other harnesses in it located between the spare tire and rear bumper. I belive there is a dummy cap over the plug which u have to remove to plug in the oem harness.
Should be plug-n-play
I just did mine its really easy, just behind the spare tire off to the driver side is the block there are two dummy plugs, pull the one that matches the the plug for the led lights. there is no need to drop the spare take off the tail lights with a t10 torques bit fish the wires through the top of the bed rails there are two hole on each side were the metal clips go to secure the bolts for the led's (8mm i think) under the bed are the holes ( you might need a flash light) to secure the wire to the body just push them in,the clips on the wires should line up pretty close. takes around 15min
Yup I popped the dummy caps off and it doesn't fit... From what I read it is the far right dummy cap that is white. The cap is an 8 pronged cap but the harness for the lights is 6 prong.
Sorry, u said "fuse block" so i thought u were running up to the cab. But that is a weird one
2014 and 2015 are 8 way. 2016 is 6 way. Maybe wrong harness?
From the looks of the picture the plug is an 8 prong? You had no problem with this item fitting your truck?
My truck came with this kit installed. I ordered a second kit to,use the LEDs as add on lights so that I now have 4 LEDs. The 8 prong plug is used on the 2014 Silverado. This was all that was offered at the time.
Did you just splice the wire and add the lights? That is exactly what I am looking to do....
I spliced the wire on each side at the existing light to extend the string. I was going to splice the harness where it goes up to the bed through the tail light housing, but I already had my Bedrug and bed sealer kit in place. So it was easier to just extend on each side at the current light fixture.
Seller sent me the 6 way and it was advertised for fitting 14-16. Won't accept return so I am stuck with a kit that fits a 16 and not my 15.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
