Bed LED wiring question
Espo720
Use the dummy plug - drill out the needed locations and pull out the wires and pins from your 6 way plug and shove them in the 8 prong dummy.
Sorry you have to go through the hassle but it may be your only choice if you want to use it.
Otherwise sell it off to a 2016 owner in the marketplace here.
If you opt for the drill and shove method, be aware that the terminals are different from '14/15 to '16. Not sayin' it won't work but GM service info shows different test probes for checking the terminals. Whatever you do, make sure it is weather tight!
  • 1 month later...
Seller sent me the 6 way and it was advertised for fitting 14-16. Won't accept return so I am stuck with a kit that fits a 16 and not my 15.
Do you want to sell the harness? I'd buy it for my '16 possibly... Another thread a guy with a 14 or 15 said he bought this harness for his project: http://www.gmpartsdirect.co/oe-gm/22878806?origin=pla&gclid=CLqv2aeLk8sCFQEdaQodPnEPuQ
I'd give ya $30 shipped for your harness then you could grab that one what should do the trick for you.
Let me know! By either quoting this post or send me a private message.
Thanks,
Aaron.
  • 1 month later...
Well, I ordered a kit also. The kit came with a 6 prong plug but my dummy plug is 8. I have a 2016.. I thought it was supposed to be a 6 prong... really confused...
