I own a 2014 Silverado 1500 with heat and power mirrors (no signals ) and my buddy has 2016 mirror that has signals built in that he is selling and was wondering if they would work on mine. The mirrors will fit but not sure if the signal will work. I don't know if there is already a post about this I tried to search for one but had no luck thanks
No. You would need to run the tow mirror upgrades to make just the signals work, so new door harnesses and a special jumper harness that is required for 2014 trucks. The truck is sort of wired for mirror signals, but the circuits for them are not to the body side door harness connector. The jumper completes the circuit to the door body side connector, then the new door harness would complete it to the mirror.
Now...if there is any open cavities in the connector for the mirror on your truck, you could add a terminal end, some wire and try and tap into the flasher circuit. Would be a hell of a lot cheaper, if it can be done.
AND, I believe you have to have GM turn on that feature thru a reflash of the computer... Once you do run the three wiring harness'.
Here is a simple way to tell:
If you don't have the memory seat buttons above the driver's door handle then you don't have the correct harnesses or BCM software to make the DL3 mirrors work (don't ask me why GM bundled it this way but they did).
So do you guys think the mirror plug will plug in to my factory harness ? Or are the pins different for different years ? And if so will the power and the heat work but no signal and fold and just hard wire the signals somehow after ?
So I have a 2015 crew cab with DL8 mirrors. If I wanted to do this upgrade obviously I would need the mirrors and I would just need the dealership to reporgram the bcm for them? My cirrent mirror are power and heat but manual fold if that makes any difference.
Yep that's correct I bought the mirrors and both door harnesses from truck that's had power fold and signals and will be doing the install next week I will keep you posted
Ok thanks I kinda figured it wasn't that easy
If I was you I would just hard wire the mirrors. I did that on my truck since when I got my tow mirrors the door harnesses weren't available. I ran my wires to the BCM for signals and all since my truck was just heat and power
there is no need for programming just need to buy the switch and powerfold will work for turn signals to work either buy both door harness or hardwire them in
That's true for powerfold and turn signals but you will not get the auto-dim or reverse-tilt without new harnesses and a BCM upgrade.
I have a set of DL3 mirrors with tungsten iridium covers if anyone is looking for some
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
