I own a 2014 Silverado 1500 with heat and power mirrors (no signals ) and my buddy has 2016 mirror that has signals built in that he is selling and was wondering if they would work on mine. The mirrors will fit but not sure if the signal will work. I don't know if there is already a post about this I tried to search for one but had no luck thanks
No. You would need to run the tow mirror upgrades to make just the signals work, so new door harnesses and a special jumper harness that is required for 2014 trucks. The truck is sort of wired for mirror signals, but the circuits for them are not to the body side door harness connector. The jumper completes the circuit to the door body side connector, then the new door harness would complete it to the mirror.
Now...if there is any open cavities in the connector for the mirror on your truck, you could add a terminal end, some wire and try and tap into the flasher circuit. Would be a hell of a lot cheaper, if it can be done.
AND, I believe you have to have GM turn on that feature thru a reflash of the computer... Once you do run the three wiring harness'.
Here is a simple way to tell:
If you don't have the memory seat buttons above the driver's door handle then you don't have the correct harnesses or BCM software to make the DL3 mirrors work (don't ask me why GM bundled it this way but they did).
So do you guys think the mirror plug will plug in to my factory harness ? Or are the pins different for different years ? And if so will the power and the heat work but no signal and fold and just hard wire the signals somehow after ?
So I have a 2015 crew cab with DL8 mirrors. If I wanted to do this upgrade obviously I would need the mirrors and I would just need the dealership to reporgram the bcm for them? My cirrent mirror are power and heat but manual fold if that makes any difference.
Yep that's correct I bought the mirrors and both door harnesses from truck that's had power fold and signals and will be doing the install next week I will keep you posted
Ok thanks I kinda figured it wasn't that easy
If I was you I would just hard wire the mirrors. I did that on my truck since when I got my tow mirrors the door harnesses weren't available. I ran my wires to the BCM for signals and all since my truck was just heat and power
there is no need for programming just need to buy the switch and powerfold will work for turn signals to work either buy both door harness or hardwire them in
That's true for powerfold and turn signals but you will not get the auto-dim or reverse-tilt without new harnesses and a BCM upgrade.
I have a set of DL3 mirrors with tungsten iridium covers if anyone is looking for some
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
