What are some of the payloads you guys with 2500's are getting?
On average I'm seeing 2100-2300 a few around 2650 and even a handful at 2800. I cant see much of a difference to the neked eye of what is extra on the 2500hd that is getting close to 3k payload. Trims are the same engine and trans as well
  • Replies 30
Sounds awfully low. What cab config and drive train are you looking for specifically?
My regular cab Z71 6.0 with 17" wheels is somewhere between 3200-3300lbs payload on the door tag. Ones with 18" wheels are 3300-3500lbs payload. I'll try and check a couple trucks on the lot if I get a chance.
No,not really. Your's is the odd where is it higher..watching them roll down the final line now. Other than tires I cannot tell a difference of why most average 2100-2300 and just a few are over 2500. Same truck same trime two different payloads
I looked at several 2500s, both 2015 and 2016, all gassers, all CC 4x4s, all above 2600 pounds. So I don't think mine is an odd one.
Just took a peek at my door sticker - right under 2300. 2015 crew cab, standard bed, duramax, 4x4.
Its bugging me to say the least, i am not looking to buy diesel, but would like to know why some are higher. Excluding engine
The 2 posts above are mentioning diesels. Diesels are heavier, thereby lowering the payload. I really think the low numbers you were initially discussing are for diesels.
Like I said, I looked at several gassers, in their heaviest configurations (crew cabs, 4wd) and all were above those figures.
Just thought of something else, each truck I looked at had the snowplow prep package. Wonder if that makes a difference on the GMs. I know it makes a difference on the F250s.
    67elco
    67elco
  • Who's Online   4 Members, 0 Anonymous, 1,318 Guests (See full list)
