Icon suspension reviews
akkrezz
Has anyone put an Icon suspension system in their truck yet? If so, what stage did you get? Im thinking about possibly purchasing these in the future but can't find any forums on here about people who already have them and what their reviews are.
I know Bilstein 5100's are good and that 6112's will be awesome whenever they come out. Ive read quite a bit up on the fox setup also. Just really only looking for input on the Icon suspension and how it rides compared to other brands and whatever else.
Thanks for any input!
  • Replies 42
I don't recall seeing a member posting about Icon. Try the search function and read thru the hits you get. King and Fox are the most discussed on this forum. If you don't find anything here, try Google.
Im surprised not many people have tried icon out yet. They seem like they're a pretty solid suspension system
I have Icon Stage one on my 2015 GMC ALl-terrain. I absolutely love it. The reason I went with the Icons was because I had them on my last truck(toyota) and was so happy with them. Also, there seem to be many issues with the fox 2.0's. The Icons are 2.5, so you may pay a bit more than Fox, but worth it imo. It is literally night/day as compared with the horrid Rancho suspension that came stock on the all-terrain model. They gave a 2" lift out of the box, and now my truck is set at exactly the right height. I got them installed by ORW in Escondido, ca. Great setup for the casual off-roader. I did not go for the higher stages, because I am on-road majority of the time, and only offroad for camping and going to snow/mountains with family. I can not say enough good things about them, no issues what so ever. For more in-depth reviews, go to the Toyota forums, they are so much more popular on Toyotas, not sure why more people dont use them on GM trucks!!!
Good luck, Mike
I got the ICON "Extended Travel" front coilovers that require a new upper arm: http://iconvehicledynamics.com/shop/chevy-gmc-1500-coilovers-shocks/17-2007-up-gm-silveradosierra-1500-extended-travel-front-coilover-shock-kit.html .
They're about 1-1.5" longer than stock (hard to measure exactly off the truck):
They're certainly long enough you don't want to stuff them in there with the stock arms. I got Cognito arms as I wanted balljoints instead of the uniball and they look a bit beefier than the ICON arms.
Out of the box they gave about 2" of lift. I eventually adjusted them up to about 2.5" by turning the perch a couple turns. They can be adjusted on the vehicle without fear of the collar slipping on the threads since they use a solid collar with a set screw. I used their wrench and a small tube as a breaker bar to give me a little more leverage. It's not easy but not that hard either.
These particular shocks increase your suspension travel about 2" from stock sized 5100's.
Like Mike above I can't say enough good things about them. The ride and handling are simply fantastic. The handling on the street is much more "sportscar-like" as transitional body roll, brake dive, etc are dramatically reduced. They provide a much more solid (less bouncy/floaty) ride than the 5100's in handling maneuvers or towing.
And yet over bumps they are much softer. They soak up bumps amazingly well. The difference between these and the 5100's needs to be exerienced to be believed. I drive at speeds offroad now that would have been nearly suicidal in prior vehicles. They're digressively valved, as are Bilsteins, but being a much larger, higher quality shock they seem to do both much better--be extremely firm controlling body motions for solid handling, while being soft for sharp wheel movements over bumps.
I had already replace the rear 5100's with 5165s with 255/70 valving and thought those were enough of an improvement I didn't get ICONS for the rear. The 5165 is a good shock and the combo works well with the ICONs on front, but I'm sure there would be a noticeable improvement--especially going all the way to the ICON 2.5s so I am keeping that in mind for the future.
Icon now has billet caps for their uniball UCA's while this doesn't fully seal them it will help out alot. When I upgrade from my Bilstein's I'll probably go with an Icon system.
The tie rods are fine at that level, the next limiting factor in travel is the lower ball joints. I would not add any additional spacers with these shocks (even if you have the upper arms) for that reason, I checked. As usual, if you want more than 2.5" or so of lift you really need a real kit such as the Zone, BDS, 4" that drops the diff, LCA mounts and gives you a new spindle. With one of those kits you could use these shocks with a spacer and have an excellent combo.
Thanks for your guys's input. I think I'm definitely going to bite the bullet and purchase these in the future. They seems amazing. I was going to go with fox 2.0's but after reading all the reviews about them not being set with the 2inch level like they say straight out of the box, being a pain in the ass to adjust, and fox not having the greatest customer service, I'm going to go with icons.
And thanks mike for the info on the Toyota forums. Seems like thats all they use and love it!
Thanks, Evan
Did you cut out the droop stops because of the Icons extended travel? Cognito told me not to remove the droop stops with their arms.
I did cut them off. I don't know if I needed to or not--mock everything up and check the range of travel, etc--I just figured while the arms were off I might as well get rid of them. With a proper length shock limiting your extension travel (instead of balljoint bind) they serve no purpose.
hey guys getting ready to buy the icon standard travel coilovers my truck has the aluminum control arms i don't see any exclusions for these shocks for steel or aluminum do you think there would be any problems running these with the aluminum arms thanks
My work fine with aluminum. If you look at icon website, I believe it says works with aluminum or steel.
Enjoy,Mike
Thanks mike I could not find anything on there website that said anything either way just placed my order can't wait to get them thanks again.
Let us know how they turn out!
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
